FGS221 Switch 2x1,5kW
Guest GG
Guest GG
Hi!
Does anyone know what is the actual difference between FGS221 version 1.9 and 2.1?
I recently got two version 2.1 from one supplier and two version 1.9 from another supplier during the same week...
If there is any significant difference, it would be interesting to know.
Ulf
GG, 2.1 support fimware update
Guest cobaltjeh
  • Will there be support for the 'old' versions to be upgraded?
    Since I already have a lot of 1.7 and 1.9 devices.
    cobaltjeh, no, in 2.1 is new hardware, so old version can't support that function
    now we got version control so:
    if your device got version => 2.1 support firmware update
    Guest MrZ
  • This firmware version is that the same for Fibaro Door/Windows sensor to?
    I have got a Door/Window sensor.
    On the box it is marken with
    V2/1 EU
    09/12/12
    Is that V2/1 mening version 2.1 Just a thought
    My dimmer is marked with:
    -868- EU
    05/02/13
    And my 2*1.5 switch
    -868- EU
    09/02/13
    Is there a way to know what firmware I have got?
    Without open the box, think I cant send them back if I have opened the box.
    Is there a date or something else to check to know what firmware...
    MrZ, when you add device you will see that info in adv settings
    Guest GG
  • A.Socha, Isn't it possible to see on the outside of the box which version it is. As it is now, we are buying a pig in a poke, as we say in Sweden. We really don't know what we are buying before we have already installed the device, and then it is too late to return it to the supplyer.
    GG, you can ask them to check device is working then in setting in vera/hc2 etc you will see version, 2.1 got new instruction too
    Guest MrZ
  • Is it the same with even the door/windows sensor? firmware 2.1?
    what was V2/1 on my box?
    The 05/02/13 on the label on the box, is that manifactoring date?
    Then when was the new formware indroduced?
    Is it possible to know the date for versoin 2.1?
    all door/window we selling with version 2.1
    Guest MrZ
  • A.socha: do you sell both 1.9 and 2.1 swiches???
    Or when was 2.1 introduced?
    Can I use the date bo the box label to know then?
    V2/1 on the door/window box label is that the version???
    Is the 2.1 version of swiches marked the same way then?
    (And mynis old)
    If you can't give me an answer, so tell me.
    door/window sensors are version 2.1 dimmers/switches are 1.9 as long as I know...
    right now:
    wallplug 2.2
    door/window 2:1
    UBS 2.1
    switch 2x1.5 2.1
    switch 3kw 2.1
    roller 2.1
    dimmers 1.9 (soon 2.1 - fixed bug on s2 + remote update)
    I've found quite detailed explanation on polish part of forum,
    . Rough translation:
    Fibaro produced (till now) modules from v1.0 to v2.1. Modules differs by internal software and version of Z-Wave libraries. (Z-Wave requires that module support most current libs. at the time of release). In version 1.6 Fibaro introduced varistor protection.
    At the moment most current version of modules is v2.1 (with exception of dimmer, v1.9), v2.1 modules supports remote update of internal software. Some of v1.9 dimmers got additional filters.
    In summary:
    Modules are constantly updated in hardware and software part. Important hardware modifications where introduced in modules v1.6, and will be introduced in dimmers v2.2
    Because of presence of varistor protection, recommended modules are v1.6 or newer, and of course it's good to have most current one modules.
    PS. Sorry for my english.
    Guest GG
  • A.Socha,
    are there any known bugs/ features in any of the previous versions (version 1.7 or version 1.9) of the FGD211, FGS211 or FGS221?
    A.Socha,
    Hi
    Will it be possible to updade firmware without using a Home Center 2 ?
    I'm asking because i have a lot of Fibaro devices (FGS-221, FGK-101, FGD-211, FGR-211) but i'm using a Vera Lite as controller.
    Are there any known bugs/ features in any of the previous versions (version 1.7 or version 1.9) of the FGD211, FGS211 or FGS221?
    Any answer to this ?
    Guest Futuretech
  • GG, 2.1 support fimware update
    Hi
    I would like to know too
    Guest jrkalf
  • Perhaps it's time that you all post a support ticket or phone up Fibaro.
    The admins here have stated (sadly enough) on multiple ocasions that this is a users forum with a little bit of admin help, but for main support questions you'd have to call/mail Fibaro.
    Yes but someone from Fibaro answered to questions several time in this thread.
    It's for this reason we ask here.
    And it would be better for the community if Fibaro could answer here because a lot of ppl can be interested by the answer.
    If everybody send a mail to Fibaro support to ask the same question it's just a waste of time for Fibaro support team.
