Dear Members,
I am proud to say, that we've released stable version 3x interface.
Also, we would like to thank all forum and bugtracker power users who supports our arrangements for this release!
Thank you for your great feedback!
FIBARO Development Team
After update to this software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
WARNING! After this update all users will be deleted. Admin password will be reset.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution.
- Added support and debugging for Lua scripts.
- Automatic conversion from graphic block scenes to Lua scripts.
- Added possibility for Lua debugging.
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Power consumption options in block scenes.
- Additional options in video cameras.
- Z-Wave tab in configuration.
- New device inclusion window, informing user of new device configuration stages.
- Helios intercom support
- VoIP panel
- Information top bar and Dashboard - subpage with configurable information views
- New drenchers panel
- Views from cameras in Your Home section
- Possibility to manually add theoretical power consumption for devices not supporting power metering, visible in Energy Panel too
- Support for new device types, new device parameters.
- Modified scenes main screen.
- New Virtual Devices version - now you can add a button or slider executing Lua script.
- Changed configuration interface layout
- Moreover 3000 minor bug fixes and improvements.
  • Answers 108
  • Created
  • Last Reply
Really good job fibaro.
Can you tell us more about what is going to happen now??
Guest paogig
Great job Fibaro! Many thanks
/emoticons/default_icon_exclaim.gif" alt=":!:" />
Just two points:
A) I see that now the FGS221 1.5Kw switch is showed as one master and one slave, is this correct?
/emoticons/default_icon_question.gif" alt=":?:" />
B) .... a problem here.... if I press the "Open" button on the "Home Entry" device the doorbell rings!
/emoticons/default_icon_confused.gif" alt=":-?" /> Consider that the doorbell and the door lock are connected to one FGS221 1.5Kw switch. Please let me now !!!!
Thanks,
Paolo
paogig,
please read my PM.
Guest paogig
Replied,
thanks...
    This module should be recognized as two devices.
    Did you checked ored in configuration of this module? Please change te order and let us know.
    Guest paogig
    Hello Krystian,
    A) I am posting a screeshot of what i see...
    b) What do you mean by "order"? consider that videogate was working fine before update...
    paogig, it's correct
    s1 is as a master device
    s2 is a slave device
    Guest paogig
    Clear thanks,
    P
    After update to 3.517 my password dont work (as it says in update info) but should'nt admin/admin work?
    maxxar,
    It should be admin/admin
    Few information about reconfiguration process.
    Guest Dennis
    HELP!
    1.47 update to 3.517 and everything is opening and closing, rolluiken open en close, alarm on and of
    [ Added: 2013-03-21, 20:01 ]
    lichts on and of.. my hole house is a ghost hous now! i had to pull the power of the Fibaro 2 to stop it.
    So what now?
    Guest vayher
    HELP!
    So what now?
    Check PM please.
    Dennis, it was after upgrade? you saw window to reconfigure device?
    Guest Dennis
    After,
    Dennis,
    Check scenes that were conditioned to run with timer "at any time"
    If that was the only condition before "then" they will all continually run
    Guest pablotibis
    Hello, since I updated to the latest version 3.517 from 1.047 door window sensors fibaro always give as dead knots, work well if you wake up after a few seconds, however, are again dead, what should I do ... Help!!
    pablotibis, go to adv setting his and temporally check on option "not mark as a dead" on yes
    Hi
    I'm Having a similar issue with dead nodes. Did the update last night from 1.0.47 to latest 3.517.
    Now seeing a few dead nodes cropping up, the most regular is the Everspring ST814 temp sensor, however some other devices such as Everspring on/off are going dead too. I've seen the option to 'Do not mark as dead' in advanced for devices but the scale of the amount of dead nodes I get surely something isn't behaving as it should?
    Also noticed on the HRT4-ZW, the temperature reading is being used as an energy reading. I'll add this to the bug tracker.
    Paul
    Enigma, problem with HRT4-ZW is fixed so you don't need do that
    we testing one fix who can help with dead device but we need more time to test it, that way we suggest temporally use that option
