Dear Members,
I am proud to say, that we've released stable version 3x interface.
Also, we would like to thank all forum and bugtracker power users who supports our arrangements for this release!
Thank you for your great feedback!
FIBARO Development Team
After update to this software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
WARNING! After this update all users will be deleted. Admin password will be reset.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution.
- Added support and debugging for Lua scripts.
- Automatic conversion from graphic block scenes to Lua scripts.
- Added possibility for Lua debugging.
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Power consumption options in block scenes.
- Additional options in video cameras.
- Z-Wave tab in configuration.
- New device inclusion window, informing user of new device configuration stages.
- Helios intercom support
- VoIP panel
- Information top bar and Dashboard - subpage with configurable information views
- New drenchers panel
- Views from cameras in Your Home section
- Possibility to manually add theoretical power consumption for devices not supporting power metering, visible in Energy Panel too
- Support for new device types, new device parameters.
- Modified scenes main screen.
- New Virtual Devices version - now you can add a button or slider executing Lua script.
- Changed configuration interface layout
- Moreover 3000 minor bug fixes and improvements.
  • Answers 108
  • Created
  • Last Reply
berga_s, we testing new patch who will help with dead node, that way i was said to check on temporally
Guest paogig
Paolo
Guest pablotibis
Hi, I can not view the list of iphone connected, push notifications to iphone not work. Do you have any idea?
pablotibis, I think you need to be logged in as admin
Guest berga_s
How is possible to order the rooms?
In the 1.047 there was the possibility to move up or down each room.
It would also be useful if there was the possibility of ordering each icon in each room.
Guest pablotibis
Guest Lode
Correct !
Socha could you help me!!! I did the update and averything well, I decided to remove all my zwave module in order to resetup everything. At the end I was not able to add again any module due to the fact when I pressed "add" button nothing happen.
I tried to restart my HC2 but used wrong button and so I think I fixed IP but not I'm not able to access to it. Tried with a laptop plugged direction after HC2, true my lan, true a new router, true HC2 finder, not at all able to access it... A really crazy thinks, how could I do in order to access again to my HC2?
Thx a lot
lolomail, you dont need that to resetup
you was delete device from hc2 chip by device is still memorizing hc2 that way "add" not working
my suggest is to use backup and get again all devices and then go to configuration->zwave -> reconfigure all device (if you dont have backup on 3.x then do hard recovery ->1038->1040->1047-> go to backup and use autobackup "1.047->3.517") and then again update to 3.517
but if you really want add all device again manually then remember that device must be in close range and first press remove device and later add device
check pendrive and unplug and then plug again power then turn on check then (you should saw 3 leds on)
Thx a lot
I know it is in polish, but this should help You get access to Your HC2. You have pressed another button and Your hc2 has now static ip. Hope this will help You
First of all thx a lot for your quick replay
Socha, thx for the tip, I will try it so. In fact when I removed all devices I think that HC keept them in memory and this was not good
/emoticons/default_icon_cry.gif" alt=":cry:" /> . After that the IP address was changed to an address which was out off range of my lan.
I started restore sceance and get hand on HC2, now I'm restoring the backup that HC2 did during 3.517 update
/emoticons/default_icon_wink.gif" alt=";-)" /> . I will go in reconfiguration soon
/emoticons/default_icon_cool.gif" alt="8-)" /> .
Wasil, thx a lot it's so easy / stupid that I didn't think to do that
/emoticons/default_icon_redface.gif" alt=":oops:" />
Laurent
[ Added: 2013-03-23, 19:02 ]
Socha, one question, when I removed all devices each of them forgot the link to HC2 but in my backup of 1.47 all those devices are still existing in HC2 files.
Which is the best way to do?
Restore the empty 1.40 backup that I have update till 3.517 and after add all devices?
Or search to recreate link between HC2 and devices under 1.47 before going to 3.517?
Thx a lot for your help
Laurent
lolomail, on version 1.047 do recover backup then you will get them all working again then update to 3.517 (yes
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">)
info
reset z-wave removing memory from hc2 but device still remember hc2 that way before next add you must use remove device
But as I did an exclusion of module, does module remember HC2?
I'm asking that b/c with my backup I can see all my previous setup but as I did exclusion of module now no one answer to HC2 order
lolomail, no, that one you gonna add them again to hc2
Hi -
My box became unresponsive just now, showing 503 error. I tried restarting the services but that did not resolve anything. I have to shutdown and restart the box. After it came back up, I had yet another dead node - Danfoss living connect.
This is the very first time a freeze happened to me, all the way since my initial version 1.037. Quite disappointing and concerning, given that this is supposed the be the next great and stable version...
Has anyone else experienced this?
Guest Sander
Hi -
yes! Same here!!! Turned off auto scene to go to bed. Hour later lights back on and HC2 not responsive anymore!
I noticed ordering of devices in now done by Device ID.
Until v1.047 it was ordered by Device Name, which was more convenient for me.
Can this be selected in v3.517? or in one of next versions?
Same counts for ordering rooms, as berga_s already stated.
Guest vayher
Hi -
Check PM please.
Guest vayher
Hi -
Check PM please.
In FW 1.XX I used scenes with conditions but in the new architecture the way it uses conditions acts really strange.
As you can see in the attached file the scene should look up to the condition If Alarm Status is "Thuis" and...... then
But only the first works, the rest also triggers the scene even if the condition has another value.
