Guest sk8er000
hi everybody,
i need your help to solve a problem which is going to make me mad!
I have placed a SM103 Everspring (Sensor 1) below the garage door and a FGK101 FIbaro (Sensor 2) at its top.
there is a relay which controls garage door activity through a virtual device (i can't use the module fibaro roller shutter).
what i want to do is to prevent the garage door from being stopped halfway manually.
when it's "sensor 1 safe" and "sensor 2 breached" the door is completely opened
when it's "sensor 2 safe" and "sensor 1 breached" the door is completely closed
it takes about 20 second to open/close.
i've tried to reach my goal adding these two scenes.
scene 1
sensor 1= breached 0 seconds
and
sensor 2= breached 120 seconds
then
virtual device
scene 2
sensor 2 = breached 0s
and
sensor 1 = breached 120s
then
virtual device
but there is a problem with these two scenes:
if the door is completely opened and i activate the scenes, when i try to close it (so both sensors are breached for only 20 seconds and then sensor 1 breached and sensor 2 safe) after 120 second the door opens again automatically.
if the door is completely closed and i activate the scenes, when i try to open it (so both sensors are breached for only 20 seconds and then sensor 1 safe and sensor 2 broken) after 120 second the door closes again automatically.
how can i fix it?
thank you in advance!
[ Added: 2013-05-02, 12:27 ]
I SOLVED THE PROBLEM!
I've used the "devices group" option.
this is the working scene:
devices group (both sensors) == breached 60s
then
Garage input
