budda 5
I'm running the latest beta 3.548
I've never managed to get a scene to work which was designed using the graphic block mode.
I'm okay with LUA scripting, but sometimes like the idea of just clicking some blocks around - and it makes it appear easier to modify some values later.
Anyway, I was trying to make a simple scene which reacts to an Everspring motion sensor event and turns on light via a Fibaro dimmer module.
Attached is my attempt at the graphic block scene. It doesn't work. Converting it to LUA script produces:
The above LUA code seems very "light" on functionality/logic!
AM I missing a trick when working with scene graphic block configuration?
4 answers to this question
