Another Big Problem
My HC2 has Crashed 10 days ago it has been repaired online by support 2 days later and now has crashed again...
I'll change my opinion about this product, it's not stable !!! since new release version the HC2 has been unavailable 2 many times.
It'll be hard to continue with something I can trust on it!!!
600 euros and Many hours of params to trash can
I put the wrong code, The one who set up variable Nightime to 1 is:
And Nightime to 0:
Nightime to 0: never will work in monday
you was eat
That is sunday, because in the HC2, if I check value monday and I go to lua, it apppear
Shad, you got right that is sunday, but still bug is bug and that is the reason that script was stop and was start again in monday
for
you never change variable Nightime to 0
Ok I see, I make a change on monday to test tuesday but I make a mistake, but on tuesday is also not working like I said.
from what i see that is more problem with your scenes then with system
let do easy test
after
add
and after
or
add
and before
add
Nightime to 0 and Nightime to 1 should got that same value after week. I think that you change Nightime in other scene
and to be sure create new scene where Nightime will be trigger and gonna +1 new variable
then if new variable == how_many from Nightime to 0 and Nightime to 1 then all works good if new variable will be bigger then that Nightime to 0 and Nightime to 1 mean that other scene was change that variable
I can do the test, but the only scene who change value of Nightime is Close Blind and Open Blind Salon.
Close Blind set value to 1.
Open Blind Salon set value to 0.
After I use getGlobalValue("Nightime") to know what do in the scene.
A.Socha while you are there, could you please tell us if Fibaro has plans to integrate UPS systems and all the stuff that would go with it (auto start when power back etc..)
See my question upper in the thread
Don't think they are going to integrate UPS system, but boot when power supply is back would be nice.
did someone try to make hc2 Wake on Lan ( magic packet ? )
My raspberry pi could wake my HC2 when power comes back (pi surely boots when power comes back...by design
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> )
[ Added: 2013-05-30, 21:20 ]
Just because i like to share information, I've had a private message stating that th hc2 should power up after power failure (when power comes back), which is fine, but also totally expected and normal behaviour for a system that needs to be on 24/24.
As answered, the point was to investigate if possible to autoshutdown the hc2 before end of ups battery (to have a clean system shutdown), and be sure it will power up once power is finally back.
I've simulated the test by pressing power button (i don't know how to shutdown properly via lua), and once the hc2 was totally off, i removed power plug, then reinserted:
And what I supposed happened, hc2 remained off (until i press power).
still gotta check WOL
