Hi all,
I wrote a plugin for
to controller zwave modules.
the plugin is able to:
-Turn on or off a light
- Activate/Run Scenes.
- Request the status of a peripheral "temperature, humidity"
- Automatic selection of the type of peripheral. (sensor, dimmable, etc. ..)
- Information from the XML file with the name of the peripheral and the ID.
- Response SARAH adapted to the device (if temperature sensor, sarah gives the value in degrees).
a big thank you !
work like a charme !
    Example to give voice to HC2:
    Nice video
    You can change the language? to English, Spanish, German.
    Sorry for my Google english
    SARAH use the voice of your computer. SO it is Ok for you. Yuou need to write your sentence in the config file of the addon.
    Hi byackee,
    soory but i can't make this work.
    Sarah is at 192.168.1.83:8080
    and i have a variable in my HC2 witch is called "IphoneG".
    A LUA script set this variable to 1 when iphone is pingable else 0.
    i made a virtual device with a button in LUA with the following code.
    but when pressing it, i have an error.
    do you know what's going on ?
    [/code]
    [ Added: 2013-05-28, 15:37 ]
    Mmmm... changing TCP/IP to 8888 for WSRMacro without succes ...
    keep searching.
    [ Added: 2013-05-28, 16:22 ]
    it seams it's some kind of config with sarah.
    when testing
    it work.
    but when testing
    it don't work.
    (Windows firewall is down)
    Guest deraaij
    Wow, cool! Unfortunatly i don't use Windows anymore...
    deraaij,
    Like me, I have only one windows, but it is a big tower, so don't want stay on all the time.
    Guest deraaij
    deraaij,
    Yup, still need to find time to look for an option with a raspberry pi...
    I am going to stop raspberry and do a big server (php + mysql to do my own graphic, samba for my movie, sms gateway, card sharing)
    Hi byackee,
    [/code]
    keep searching.
    when testing
    it work.
    but when testing
    it don't work.
    this is weird, do you use windows 8 ?? can you check your host file: C:\WINDOWS\system32\drivers\etc\hosts , need to put 127.0.0.1 localhost
    Test with my another plugin "speak"
    This plugin use port 8080
    [ Added: 2013-06-01, 22:21 ]
    deraaij,
    I understand, for me i use intel NUC for xbmc and SARAH
    [ Added: 2013-06-01, 22:22 ]
    Ok, you can use it with virtual machine
    Would be possible to make a small tutorial for beginners, such as turn on/off a light talking to sara?
    I would like to make it work, it seems to me sara a very good idea.
    Very very intersting, just can't seem to get it to work under windows 8.
    Any short tutorial would be great! already looked on your website. But still no luck...
    The icon of the house in my taskbar never appears...?!
    Hi, you can find help on googl+ community
    do you use kinect?
    I don't use Kinect, so I also didn't install the Kinect sdk... You think I should install that aswell? The server is obvisously running but the icon in the taskbar never appears and it doesn't respond
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> feels stupid if your talking to yourself the whole time
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
    LOL
    /emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> can you try to reinstall .net framework 4.5
    Ah Just installed the Kinect SDK and checked the log files for some other errors. and got it working now
    /emoticons/default_biggrin.png" alt=":D" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> thanks for your advice of the google+ got some info there aswell
    You don't need to install kinect sdk, just framework, and you must start WSRnode ad WSRMicro
    I updated the Time.js script so it speaks out the oh clock for some minutes and uses the " quarter past", " half past" and " quarter to" indication.
    for instance: instead of 12 hours 15 it now says: quarter past 12
    I can't seem to get the scenes working... should the first tag be under launch?
    I added functionality to my plugin:
    - Launch scenes
    - Add automaticly all modules to SARAH database
