haha I got the scenes working to
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I noticed there where some bugs in there... But I will download yours when you update it and see how it works!
I wanted to build in a check to see if the node is dead... so it can report back. Further maybe change the name to an ID.
As you can just search for that. names of a node change, but the ID doesn't.
By the way: this is what I use to make Sarah talk from the HC using the "parle" plugin:
Virtual Device Code:
Remark: the variables can be changed from different scenes, so you know what text you send to Sarah, but you cannot use a space but have to use %20.
So a variable text looks like this: "this%20is%20a%test"
    Link to download plugin 1.2
