I am trying to build a scene that is executed only at a certain time of the day IF and only IF a GlobalVariable has value == 1 (as in attached jpg). The problem:
- if the "Triggering variable" is flagged for the GlobalVariable, then the scene is executed every time the variable is set to 1 during the day (that is, every time a specific sensor is breached, while I want it to be executed only once at 20.30, if the sensor is breached at least once during the day)
- if the "Triggering variable" is not flagged, then the scene is not executed at 20.30, even if the GlobalVariable has value =1 at that time
Any idea of what am I doing wrong? shall I just move to a LUA-based scene?
Thanks,
Riccardo
8 answers to this question
Check the code in LUA, this might be an error in HC software.
Which version of HC software you are using?
I have created exatly the same scene and it's working…
EDIT
check scene in LUA if the condition has the right time format:
…...string.format("%02d", currentDate.min) == "20:30"…..
    Hi Richo
    when I converted to LUA I read
    so it seems correct! Any other idea of what may be wrong? I'm using 3.548
    Thanks!
    Riccardo
    rcanetta, to be sure you got option on yes "start with hc2" in that scene?
    Hi, now it is checked but it could be that it wasn't before, I noticed it when I converted to LUA - let's see what happens tonight
    Thanks!
    Riccardo
    How often will this scene logic be checked as i've seen some scenes run in an endless while() loop which seems wrong (to me) compared to this which is a simple If Then...
    Rcanetta, did this work for you ?
    I have a similar problem where I'm using the iPhone ping technique so the hc2 knows I'm home, then at 6am I want it to check the athome variable and activate the scene accordingly.
    I'm finding tho that when I get home anytime of the day, my bedroom light comes on
    Please update
    Please update
    Yes, my problem was probably the missing "start when hc2 starts" flag. Also, Check that the checkbox under "triggering variables" is NOT selected.
    Hope it helps
    R
    Hope it helps
    R
    Ive checked these and it hasn't cured it. the bedroom light still comes on regardless of time.
    It does work at 6 am in the morning but also reacts to the status change. i shall monitor over the weekend to see if the light comes on at 6 whilst im not there.
    [ Added: 2013-07-08, 23:09 ]
    Ok I think I've fixed it.
    Because I was using blocks to make this scene, I converted it to LUA and it still showed the variable at the start. I deleted that and now it does not come on when I come into range. It should however come on tomorrow at 6am.
    Good night
