Hello Fibaro, can you share with us informations about your new module ? I have read some informations about the module on the polish forum but I want more
/emoticons/default_laugh.png" alt=":lol:" />
When could you introduce it on the French market ?
Best regards.
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
If google is my friend, I prefer wait to connect my led strip ^^.
Krikroff,
Soon we will release marketing materials here, you will now details.
/emoticons/default_icon_smile.gif" alt=":-)" /> If any questions please feel free to ask!
Awesome....
A.Socha,
SO if I understand weel:
- Power voltage 220V
- You can connect 4 detector (humidity,... whatever you want), with maximum 0-10V input
- you can control 4 light 12-24V
or
- 1 led strips.
That right???
If it is that, is very nice.
Wow, visionary
Great idea to include links to different sensors.
    A.Socha, This module is really very impressive!
    /emoticons/default_icon_biggrin.gif" alt=":-D" /> Have you already an idea of ​​the availability of this product?
    Very nice, best regards.
    Guest Fidziu
    Shad,
    its low power device You cant connect 220V directly.
    it has 4 chanel inputs and 4 ch. outputs (but you cant connect 8 devices running simultaneously, 4 is max, does not matter input or output)
    You can conect 4 diferent switches and 4 ch. rgbw led strip.
    or if you wont you can mix it: connect 2 diferent sensors and 2 low voltage lights and dimm them.
    our example: garage master is that it has connected rgb led strip and 0-10distance sensor to ONE module.
    if you decide yo can connect up to 4 diferent 0-10V sensors to one rgbw module.
    Shad, Power voltage 12/24V
    yes, you can do mix too 2 in devices and 2 out devices
    - 1 led strips.
    yes RGB or RGBW
    Imax = 12A
    Ok, that is very good module, hope is come avalaible quickly.
    Damn.. I'M really looking forward for this device to come...
    /emoticons/default_icon_eek.gif" alt=":shock:" />
    It shows that it supports analogue sensor, does this mean by cable?
    Thinking of my weather (WMR200) station that have 4-5 sensor but does not use cable...
    If not, what type of weather station, wind, rain sensor is supported?
    You have this information in official product review even with some examples
    Guest spazpeker
    When are you going to publish the manual ?
    Looks great! Been waiting for something like this. When will it be available?
    Analogue sensors are always cable
    This module can handle any 0-10V analoge sensors like wind, temperature, humidity, preassure, rain sensors
    Can it be connected directly to a wall switch?
    My goal (as I currently have it installed) is to have a wall switch to turn the RGBW lights on or off, and to be able to control the colour using HC2. Currently I have a Sunricher RGBW controller with WiFi, and a Fibaro 3 kW switch to switch the power supply (AC/DC adapter in a wall plug).
    The easiest solution would be that HC2 can control the Sunricher controller, but unfortunately it seems to communicate directly over tcp instead of http.
    It seems the Fibaro RGBW solution is designed to be "always on"? Or to be switched on/off together with other lights (using scene)?
    Does anyone have a suggestion for a 4-gang wall switch to connect to the RGBW module?
    I ended up buying the 2-gang Jung 535U, but can’t find a 4-gang equivalent.
