Looks great! I'M really looking forward for this device
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
Can it be connected directly to a wall switch?
My goal (as I currently have it installed) is to have a wall switch to turn the RGBW lights on or off, and to be able to control the colour using HC2. Currently I have a Sunricher RGBW controller with WiFi, and a Fibaro 3 kW switch to switch the power supply (AC/DC adapter in a wall plug).
The easiest solution would be that HC2 can control the Sunricher controller, but unfortunately it seems to communicate directly over tcp instead of http.
It seems the Fibaro RGBW solution is designed to be "always on"? Or to be switched on/off together with other lights (using scene)?
This device is designed to be connected directly from the wall switch, but please notice that it needs additional DC power supply. You can control it from HC2 interface and from the scenes. Also it can be controlled from other Z-WAVE modules using associations.
Guest mhn
This device looks really nice.
How is the change for it to work with Homeseer?
Regards
Morten
So, just to make sure:
I run a 12/24V DC power cable to my wall switch. The RGBW module is powered by this, and connected to the wall switch (pulse switch) to turn the led lights on/off. Correct?
Some french web site say is going to be on sell next week for the same price at your other device.
Can you confirm, because I am going to be the first to buy some of these one ^^.
    + 1000
    Already buy it on domadoo^^.
    I can't wait 7 days to got it.
    Guest dsilletti
    Wowwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww!!!!!!!!!!
    Domenico
    rb338,
    Yes - module is powered by the same voltage as LED/RGB/RGBW strip and it is controled by GND signal from wall switch (we will release full documentation with connection diagrams within next days).
    mhn,
    It should be recognised in the Homeseer interface as 4 dimmer modules (each one for R, G, B, W channel)
    Guest mhn
    Then it's just waiting. I really look forward to this devise.
    Can anyone recommend some good led strips ? I brought some from eBay a few years ago and some sections are only showing blue
    Can one connect the DS18B20 Digital Thermometer to this module? Or one would need the Universal Binary Sensor in between?
    Daniel W,
    You can not connect DS18B20 1wire sensor to this module. It supports 0-10V analogue sensors.
    johnwlawrence88,
    Please check on the amazon.co.uk and e-bay. Also local electronic and DIY shops.
    Ok thank you Krystian for the prompt answer - much appreciated.
    Daniel W,
    No problem
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> in any questions please feel free to ask!
    Do you you think it is possible to use a FGS211 to control the power supply , and the rgbw driver to dim the led with a double push button ?
    The power supply will have a huge inrush current of 75A on start up.
    Anthony
    The Fibaro RGBW controller is the best z-wave product i saw on the market really ! Powerfull IO configuration and flexible, Wow...
    A.Socha, my product is in v2.2 (08-07-2013) and the documentation is for 2.1 to 2.3, what is the difference between them ?
    Thx for this product and now I'm looking forward to seeing more ...
    Best regads.
    Krikroff, 2.1 that was a version for beta tests
    2.2 is prod version
    2.3 will be when zwave will update sdk for example
    2.2 is prod version
    Thanks for the quick response. Can i safety use the RGBW Module with HC2 3.553 beta or it's more prudent to wait for 3.553 stable release?
    Krikroff, yes you can
