Greenwave Reality Powernode 6 outlets
This pretty cheap and effective outlet is superb. Fibaro hasn't got an alterative for this 6 outlet device. In a computer room or at the audio or tv shelf it can be easily used.
This outlet can measure the power consumption for each outlet, however Fibaro doesn't support. Why is Fibaro doing this? My vision at the long term is, that if Fibaro should support as many devices from third parties, because their product/platform will become more popular. If they follow the short term strategy, Fibaro can sell their own products (if they would have such a device) and make profit out of it but the popularity of the platform still has strong competition in the market.
There is a solution to enable power consumption.
I saw on the forum that mr De Raaij found out how to enable this by adding records. However the HC2 is closed now for ssh access.
Can somebody explain how to add the following records to the HC2 or are we really depending on the strategy of Fibaro?
tabel: NEW_Property
INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','valueSensor','0','CURRENT_TIMESTAMP');
INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','unitSensor','W','CURRENT_TIMESTAMP');
INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','valueMeter','0','CURRENT_TIMESTAMP');
INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','unitMeter','kWh','CURRENT_TIMESTAMP');
INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','meterSupport','{"vMeterSupport":[{"meterType":1,"sMeterType":"kWh","meterScale":0,"sMeterScale":"","value":0,"enable":true,"lastPolling":1358584209,"configuration":true,"retryConfig":0},{"meterType":1,"sMeterType":"W","meterScale":2,"sMeterScale":"","value":0,"enable":true,"lastPolling":1358584209,"configuration":true,"retryConfig":0}]}','CURRENT_TIMESTAMP');
INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','sensorSupport','','CURRENT_TIMESTAMP');
table: NEW_Action
INSERT INTO "NEW_Action" ("Device_Id","Name","Arg_Mask") VALUES ('60','resetMeter','1');
Thanks, I'll check that out
I bought mine from ControlLiving.nl and they at least sent me one to Sweden. I can't really see why they wouldn't send to Finland.
I'm probably missing something here, but where the h**l is the webshop on their page? I can see the cart on the right hand of the screen.
Nevermind, found it eventually.
I really love the idea of this product (I think, Dutch is jidderish for me
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />), but it is out of stock. Anyone seen this anywhere else?
Top bar link menu, "Shop systeem". Here is direct link to power strip:
[ Added: 2014-02-13, 01:00 ]
I would not see either, but:
"Invalid shipping method" (Ongeldige verzendmethode) and no way to change method.
[ Added: 2014-02-17, 16:30 ]
Worked out, thnx stevenvd! Now we'll just wait for powernodes to come!
Sadly no.
stevenvd, can you help me too? i really really want to order the greenwave 6 port but i have som problems understanding the dutch
Use the english version
Thank you, I was just about to post that
On the bottom of the site you can always change to english or dutch.
