Howto siriproxy talk with HC2 question?
Hello, i read that any users of this forums have replaced lilly with siriproxy gateway, anyone can explain howto make this.
I have running siriproxy on raspberypy but i dont know how to integrate with HC2.
I am doing this - although it is far from release-ready.
I developed it for myself which included controlling far more than just Fibaro. Thus, I am using a simple SiriProxy plugin that goes out to a local website that runs PHP that parses what the SiriProxy plugin interpeted as a command. Does a
(so that "Dining Area"/"Fining Area"/"Lining Area" etc. that sounds equal) against the HTTP API on
and section and devices.
I've studied SiriProxy a bit to help my brother control a different system. Setting up SiriProxy on a RaspberryPi and have it execute simple commands doesn't require any coding, you can do it by simply changing the example provided with SiriProxy - you can have a look at the "Adding Functionality" section of this guide
But the plugin above for HC2 looks really interesting, keep us posted please!
Br
Riccardo
Br
Riccardo
Here's an old video of when I first started doing this.
The video is showing off the prototype - kind of like proof of concept to see if this was possible.
I had as a goal that rooting HC2 would not be necessarry (otherwise this would have been dead simple by accessing the MySQL database on the HC2).
I no longer use "master" as a keyword identifier, but rather just say "Turn on X".
Development has completley halted so maybe I should release it on github so that others can improve...?
