AEON labs Engergy Meter
remcoploeg
I have just installed the aeon labs engery meter. I connected the two clamps in my main incoming power station. I have connected the meter with HC2 and the meter was connected. I have one main with 3 slaves. But the wattage of the devices stay on zero watt. In the log of fibaro I see incoming traffic:
[13] ID 36: Received parameter report, value = 360
[13] ID 36: Set parameter 112, value = 3600
[13] ID 36: Received parameter report, value = 3600
[13] ID 36: Set parameter 113, value = 7200
[13] ID 36: Received parameter report, value = 7200
It looks that HC2 is receiving something but doens't update the wattage on my device. Somebody any idea? I have looked the forums but couldn't find any post on this. Do I need advanced paramters to setup manually?
I have in only connected to one phase. Beside of that I only use the batteries and not the adapter with the AEON
Small update:
I have connected the AC in stead of the batteries. I reconnected the meter, and I received an update (358W), after that (for 1 hour now) no updates on the wattages. I seems there is a problem with sending information to my HC2.?
Update:
I have changed the polling time ( to 20, is that ok?) on the master device, and now I receive updates...
thanks!
Small update:
Update:
thanks!
change you polling time to 0...20 is very low....0 is default global.
set parameter 11,112,113 to 8 sec....
hello
i have also installed this energy meter 3 phase version
in order to see update results on the panel i just had to set polling time interval to 20
all other parameters i have left them at default...
so every 20 seconds i see the transfer ok at the bottom of the box which then refreshes the value of the watts i consume.... then it goes back to the kwh value....
dont know if there is other way to do this...
christos
