Lights automation [LUA][3.562+]
Polska wersja:
My idea for automation lights in the house. Example of usage...
The enter-room with dimmer. Every move event turn on the lights for 3 minutes and every open door event turn on the lights for 5 minutes. In the last counting minute the lights will dimm down to zero - softly.
Every move or opening the door event will restart counter to 3 or 5 minutes. Manualy turning on the lights will set counter to half hour and then any other event will not be able to set counter for lower time - manual control is a priority.
Summary:
- Automatic switching off lights after counting time.
- Extension of light time based on events (eg move, doors, etc.).
- Without interfering with the manual control.
- Each light has its own timer.
- Dimming light for a defined time.
- Easy access to functions from the scene.
and...
- Everything is based on one single virtual device,
- For presentation timer and counting using slider - one for each device.
- Switching the light in the scenes you can make in the traditional way, or...
- Or simply by setting the slider value (setting the timer) - nothing more!
- You can adjust the slider (timer) in many scenes together.
The whole is fully automated and is simple to implement!
And here's the recipe in a few steps:
1. Define a new virtual device with the following code as Main loop. Change only login and password for your HC2:
2. Define the sliders for each device in your home that you want to control by timer. To do this, add a slider in the virtual device with content as below:
Fields:
action must be always autoOff;
deviceId id of controlled device;
defaultTime (optionaly) - default timer when the switch is controling manualy;
defaultValue (optionaly) - default maximum dimmer value;
dimmTime (optionaly) - time of dimming on the switching off event;
NEW! wakeTime (optionaly) - wake up period in seconds if devcie is dead.
3. (Optionaly) For presentation on the home screen you can define two elements in that virtual device. One more slider witch id globalSlider and one label id globalLabel with title eg. Turning off:.
That's all.
Just a way to use this functionality in scenes:
Instead of selecting the turn on action, just select the action changes the slider to the virtual device to any value (in seconds). The light will turn on automaticly.
Good luck;)
And one more thing...
to have new futures!
Update 1.3:
- added possibilites to set timer (slider) from scenes to any value (even lower than actual) by minused value (eg. -600).
Update 1.2:
- fixed slider values preview,
- added new parameter "wakeTime"
- few others.
Update 1.05:
- possibility to turn off by slider,
- possibility to controll time in any "direction" by main slider
- icons - with animation
- bug fixes
Thanks! Very usefull.
[ Added: 2013-10-04, 09:15 ]
I have implemented it. It works great. Except for the fact that the next time that i use a dimmable light it starts fully dimmed. Is there a way to set startup value for dimmer lamps using manual on?
I have the older dimmer module without de start value option
    Try to add this lines together:
    [ Dodano: 2013-10-08, 09:59 ]
    The new version has been loaded
    Update 8 X 2013 (v 1.05):
    - bug fixes
    stoper-stop.png you have to add as main icon and assign also to main slider.
    stoper.png assign to the rest of sliders.
    I have no succes with the latest version. It doens't work at all?
    What error do you have in Debug window?
    [ERROR] 12:29:24: line 308: attempt to perform arithmetic on a nil value
    this is line 308
    if (globalSliderId and globalSliderVId) then
    Its seems de globalSlider is manditory in this version
    Search this code (at line 305):
    and swap to this:
    What result is now?
    It's working now. I added the globalSlider in the virtual device.
    btw the codeswap didnt help.
    Thanks for feedback. I'll try to fix that.
    Can this be used with a relay switch instead of dimmer? What do i need to change in your setup?
    Yes, of course. The code in slider has to look like this:
    Perfect, good piece of code. Replaced 3 other scenes with this.
    thanks !
    rafal.m, first of all great script! I have few bugs:
    1] if i move slider other then global, it will jump right back on time it was counting from. So if there is 3450 sec i move slider to 45 then it will jump right back to 3449. If I do that in Global slider, it works. In individual sliders it doesn't.
    2] viz picture HC2 3.570 graphics is repeating itself...
    feature: can't it display time in seconds and minutes?
    That is not without reason. It is protection for setting time from scenes to lower value than actual counter. Example: if you have "move detect" scene whitch setting counter to 300 sec, you don't want situation, when that move decreses time after you switch lights manualy and counter starts from 3600 sec.
    Right now it's not possible to check if the slider was changed from scene or manualy by user, so protection working all the time.
    I'm working with new version of script. The "slider view" problem will be fixed by using percentage value instead seconds.
    Good idea!
    Great work!
    I have a question or I do something really wrong. When I add the slider to 3 (minutes?) Then my lights go off after 1 minute and switch directly on again and so on and so on.
    Don't I understand the timing of the slider?
    thanks,
    Remco
    Are you clicked slider? Or setted it by scene to 3 minutes (180)?
    The slider is represents a direct of time (in seconds) to switch off. Thats all.
    Yes I clicked the slider, but also tried it with a scene
    By click you can select only time from 1..100 seconds. Are you surre, you have right sliders parameters? Can you post here screenshoots?
    Yes, see below:
    [ Added: 2013-10-18, 16:07 ]
    Here my virtual device
    You have two sliders with one device id=112. Delete one of them. Is that device is binnary swtch or dimmer?
