rafal.m 7
Polska wersja:
My idea for automation lights in the house. Example of usage...
The enter-room with dimmer. Every move event turn on the lights for 3 minutes and every open door event turn on the lights for 5 minutes. In the last counting minute the lights will dimm down to zero - softly.
Every move or opening the door event will restart counter to 3 or 5 minutes. Manualy turning on the lights will set counter to half hour and then any other event will not be able to set counter for lower time - manual control is a priority.
Summary:
- Automatic switching off lights after counting time.
- Extension of light time based on events (eg move, doors, etc.).
- Without interfering with the manual control.
- Each light has its own timer.
- Dimming light for a defined time.
- Easy access to functions from the scene.
and...
- Everything is based on one single virtual device,
- For presentation timer and counting using slider - one for each device.
- Switching the light in the scenes you can make in the traditional way, or...
- Or simply by setting the slider value (setting the timer) - nothing more!
- You can adjust the slider (timer) in many scenes together.
The whole is fully automated and is simple to implement!
And here's the recipe in a few steps:
1. Define a new virtual device with the following code as Main loop. Change only login and password for your HC2:
2. Define the sliders for each device in your home that you want to control by timer. To do this, add a slider in the virtual device with content as below:
Fields:
action must be always autoOff;
deviceId id of controlled device;
defaultTime (optionaly) - default timer when the switch is controling manualy;
defaultValue (optionaly) - default maximum dimmer value;
dimmTime (optionaly) - time of dimming on the switching off event;
NEW! wakeTime (optionaly) - wake up period in seconds if devcie is dead.
3. (Optionaly) For presentation on the home screen you can define two elements in that virtual device. One more slider witch id globalSlider and one label id globalLabel with title eg. Turning off:.
That's all.
Just a way to use this functionality in scenes:
Instead of selecting the turn on action, just select the action changes the slider to the virtual device to any value (in seconds). The light will turn on automaticly.
Good luck;)
And one more thing...
to have new futures!Update 1.3:
- added possibilites to set timer (slider) from scenes to any value (even lower than actual) by minused value (eg. -600).
Update 1.2:
- fixed slider values preview,
- added new parameter "wakeTime"
- few others.
Update 1.05:
- possibility to turn off by slider,
- possibility to controll time in any "direction" by main slider
- icons - with animation
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />- bug fixes
10
5
4
Oct 21
7
Oct 11
6
Oct 18
5
Oct 19
5
rafal.m 29 posts
remcoploeg 10 posts
emariu 5 posts
hugohekk 4 posts
Oct 21 2013
Oct 11 2013
Oct 18 2013
Oct 19 2013
rafal.m
Please login or register to see this link. Thanks Please login or register to see this link. and Please login or register to see this link. !
86 answers to this question
