Dimmer and pushbutton
Same problem here with two of my dimmers. Definitely has something to do with association with S2, thus both the dimmers worked perfectly before associated with another device.
I hope this is looked into soon by Fibaro.
Lundan, try the setup I'm trying. Parameter 41 active + direct association. Is the issue still apparent? I'm giving this setup a chance for a while, it's worth a shot. The only downside it the tiny delay that is introduced as the dimmer waits 3-500ms for further clicks but this is perfectly fine in my opinion considering the alternative.
I've changed the way I use S1 quite much since I filed the bug (lots of scenes and association with a "dimmer scene" that catches all dimmer activity and I'm very happy with this although this i a wide spread and documented issue that really should be properly addressed.
Scratch that, the issue remains. I removed the associations again.
