Still dead nodes in this version?
I still have dead nodes. a few beta versions ago it was solved, but they are all over the place again... Problem for the scenes as they do not complete and especially a problem for the more special tasks like floor heating control.... Anyone a suggestion?
  • Answers 72
  • Created
  • Last Reply
Strange, I never have dead node's. Am I just a lucky guy, or what .......
I have running 27 nodes running.
I've used this script, I don't know where I found it on this forum. But in my experience it works very nicely.
As the script works, it indicates that the nodes are not dead. It really proves that there is an issue as they recover with no reconfiguration or change in routing.
At some point in time, communication to and from a procedure in the software is not working via the rest of the software stack, the z-wave controller, the network and the device in a timely fashion. When the script runs, communication must be back to normal or it would not work.
so frustrating ... an intermittent issue. As so many have this issue it can not all be environmental.
You are lucky. I hope you have not spoken too soon.
Would love to understand the difference. Are you willing to share your config?
Robmac, what would you like to see? I have the HC2 toolkit, so if you want me to PM you something, you name it.
Just the report from toolkit would be good.
I am just prototyping a database and if it looks like it will show something, I will create a loader and analytics app.
Guest Kuuno
When we talk about dead nodes theneveryone should post floor plans w module locations and wall material. This has huge effect on dead nodes...
Here on the polish forum you can find a new version of "dead wake up" script that only starts when triggered by a dead device. I hope you can translate the tekst from polish (using i.ex. google) as I don't have time now to translate it into english.
I confirm for me, richo code works perfectly:
Of course you need to make corrections regarding your system.
    It is just normal with fibaro. When they say nothing, somthing is going to happen.
    I noticed that a few times Shad.....
    [ Added: 2013-11-26, 22:24 ]
    There are signs for new beta everywhere yes. Quite interesting things actually
    Like ?
    Why are you talking about nice things/fetures to be added to the new BETA version? I would just like a stable version first, thats all please....
    Other question: It looks like my fibaro dimmers are (power)dipping, sometimes a few times per minute. Anyone having this issue with this beta version?
    Code:
     %% properties
    13 dead
    17 dead
    21 dead
    22 dead
    23 dead
    now that gives me an idea ...
    test lots of other nodes to check if it is all nodes are blocked or just the one being marked dead
    + possibly check what scenes are running when a node go dead
    It's true that most often dead nodes appear when the scene is trying to use a device. Usually if you have many commands one after another for many devices. I try to use some sleep time (1sec) between the commands, it helps a bit.
    Anyway dead nodes still appear ...
    Since I remove a very simple scene who detect presence send snapshot to xbmc and blink red on my led strip I have no more problem for 13 days.
    So I would like to say is not bad.
    [ Added: 2013-12-03, 10:48 ]
    Have done a bit more testing on new beta and issue is still there.
    Anyone else?
    I know it is not range thanks to new fibaro wall plug.
    nodes that get marked dead all wake immediately and switch fast when HC2 is working normally.
    Have a scene logging when the nodes are marked dead and testing some nodes near hc2 when any node fails.
    I have certainly found that when nodes are marked other nodes are non responsive to commands. I suspect dead nodes and random slowdowns/lockups might be connected.
    ... Only the switches from Fibaro become dead nodes ALL THE TIME and ALL OVER THE PLACE. But I can say that the Danfoss Valves never! show as dead... Anyone else having the same?
    Marcel try to switch off all Your Danfoss Valves and then there will be no problem with dead nodes. It is becouse Danfoss try to find the way to controller (HC2) and it ask every device if this is HC2. It generates big traffic,that's why You have dead nodes.
    Don't say something that is not true. I know a number of users that have no Danfoss at all and still have dead nodes.
    [ Dodano: 2013-12-10, 00:37 ]
    It seems that HC just doesn't mark them as dead even if you take off the battery
    robmac - try to set polling time to 0 (from z-wave menu under configuration).
    Hi Lauri,
    That indeed reduces the frequency of times you spot the issue but then you would expect that as it reduces the traffic.
    That is a bit like the code in HC2 that ensures you can not set poll to too low a value based on network size. It treats a factor to the regularity of the symptom. I am not convinced it is the root cause.
    Taking that approach to the limit you could also turn HC2 off, you would never see the dead nodes but then it would not do all the good things that it can do either;-)
    I still look forward to a proper fix.
    robmac,
    Still the same with my installation
    I have developed a lot of bypasses to limit the problem with devices that are not switched on/off because of that but it's a waste of time. Still new dead nodes appear...
    I've heard that Fibaro is working on a new z-wave engine !? But officially nothing has improved in that matter yet.
    Why do You think it is not true? Danfoss Valves makes the bigger impact in Z-wave engine if they are not able to connect with controller. I am not going to say that everytime You habe dead nodes it is Danfoss fault. But they "help" to make other modules dead (making big traffic in z-wave engine) and that is true!
