petergebruers 1,268
Yesterday, one of my FGS221 Switch 2x1,5kW got stuck in the ON position. I immediately suspected the 20W LED floodlight connected to it. I had used this floodlight on my desk and I noticed at the time... that closing the contact to the supply of this light could give some really nice pyrotechnics. I think the driver does not have an inrush current limiter, or it uses a bad one. It is built and designed in a very big country, and I did not find specifications of this unit.
So, yesterday I had to remove my toggle switches, then gently knock five times on the Fibaro module behind it and it got unstuck... The switch seems to be OK, I left it in service.
But now... for a solution. The first thing I had in mind was a 10 - 60 ohms NTC in series of this driver. But I didn't have any at hand. So I thought... 20W is not a big deal... Why not put a 15 ohm resistor 1/2 Watt in series? Then I tried the floodlight on my desk: when closing the circuit the arcing was a lot less. I own 4 of these and I have now modified them all.
Please feel free to share you opinion on this!
10
6
4
Jan 26
9
Jan 11
6
Jan 31
5
Mar 7
4
petergebruers 24 posts
Mo19 10 posts
robmac 6 posts
Sjekke 4 posts
Jan 26 2016
Jan 11 2014
Jan 31 2019
Mar 7 2014
petergebruers
Hi Kuuno, thank you for sharing. Are you talking about 1) 230V halogen lamps 2) 12V halogen lamps on classic transformer (50Hz metal core) 3) gas discharge lamps with 50Hz ballast 4) Incandescent lamp
chatting
I'm stupid enough by using the Fibaro switch to turn on a relay to light up the light. Please login or register to see this image. /emoticons/default_icon_curve.gif" alt=":-/" />
Momos
So far so good. The ESB1 works perfectly so far, installed between the "live" and FGS.
98 answers to this question
