WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
Mobile apps fully working with this version:
- iPhone app - version 2.1.1 (available on the App Store),
- Android phones app - version 1.3 (available on the Google Play),
- iPad app - version 1.2 (being reviewed in the App Store, available soon).
3.580
- Testing connection with Satel alarm.
- Faster HC2 booting.
- "Undo" button after predefined alarm scene has started.
- PIN codes added to alarm (warning: PIN code will be reset after this update and has to be set up again).
- Information from Fibaro icon added.
- Entry time and exit time in Fibaro Alarm.
- Excluding sensors from alarm system.
- Excluding devices from events history.
- Possibility of setting sensor as always armed or always disarmed.
- Changes dedicated to mobile apps new versions.
- Importing gateways - information about connected gateways.
- Possibility to change temperarure unit.
- Importing / exporting virtual devices.
- Network settings fixes.
- Virtual devices changes and fixes.
- RGBW device fixes.
- Backups creating fixes.
- Virtual devices update - sleep in main loop increased to 3 seconds.
- Fibaro Alarm fixes and changes (i.e. always armed / always disarmed, multi arming / multi disarming devices, excluding sensors from alarm system, configuring sensors).
- Stopping scenes and blocking saving scenes and devices while alarm is active.
- Fixed searching for other HC2 units in local network.
- Other minor bug fixes.
Bugtracker tickets:
- 0000077: Logi
- 0000141: Włączanie alarmu z iOS
- 0000398: Error uploading .png icons
- 0000413: HC2 show me 0.01 W usage for one fibaro dimmer Turned OFF !
- 0000414: HC2 show me 0 W usage for one fibaro 3k switch Turned ON but 10W declared !
- 0000522: In API field "type" appears twice in properties node, sensor, binary light etc.
- 0000531: Show the scene in interfaces changed to "No" without notification -> scenes not visible in Iphone & Android app.
- 0000585: Device Declared power consumption does not work sometimes
- 0000631: 3.548 json.encode crashes in virtual device
- 0000723: 'modified' field in /api/devices is not updated with new timestamp after device state changed
- 0000742: Add delayed trigger to alarm panel
- 0000757: Extra options for "device kind"
- 0000942: Alarm Panel Problems
3.571
- Minor bug fixes.
3.570:
- New json library in LUA.
- User icons in remote access.
- Z-Wave bug fixes.
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Support for new Fibaro FGR221 Roller Shutter module.
Bugtracker tickets:
- 0000899: Can't turn off potential fire and freeze notifications
- 0000511: SP814 template (broken)
- 0000142: Everspring ST814
- 0000782: After HC2 restart/upgrade the RGBW module is shown as 'On' in GUI
- 0000882: Virtual Device popup
- 0000890: When setting new value for ID of a slider(not tested for other controls) the old ui..value tag in JSON is not removed
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
3.548:
- Changes related to new version of operating system repositories.
3.547:
- Fixed bug related with some cameras problems in remote access mode.
3.546:
- Solved 503 Error issue appearing for some users.
- Fixed working of scenes based on user location.
- Fixed energy graphs in live mode.
- Solved problem with diacritics symbols in devices/rooms/scenes names.
- Other system fixes.
3.545:
- Fixed displaying image from Home Entry System Helios.
3.544:
- Possibility to run scenes by Lili (please reload Lili database in configuration after update).
- Remote access scripts watchdog added.
- Added possibility to choose triggers in block scenes.
Bugtracker tickets:
- 0000487: Add/Delete GPS Points Error.
- 0000480: GPS condition doesn't work.
- 0000476: Panel ogrzewania przestaje.
- 0000460: Heating Linked Device fails to switch off Switch 2 (a.socha) - rozwiązany.
- 0000459: Modified variables don't show up in scenes.
- 0000454: Variables with space can't be changed.
- 0000437: EnergyPanel date select.
- 0000426: Option to deactivate variables as scene trigers
- 0000424: Bad slider position (cosmetic) in dashboard / actuator panel.
- 0000418: Błędne przekierowanie w trakcie tworzenia scen opartych na pozycji GPS.
- 0000403: headline.png not found in linked device panel (head of menu).
- 0000402: Unable to save new state of predefined variable value in dedicated panel.
- 0000396: Belka nazwy panelu domofonu.
- 0000387: Impossible to access the HC2 web page from iPad.
- 0000380: On the HRT4-ZW the temperature reading is being used as an energy reading.
- 0000369: Translation needed: Home Entry System Panel.
- 0000350: uprawnienia użytkownika.
- 0000341: Bad energy costs in energy panel header when switching from power usage to energy costs.
- 0000331: Temp value of HRT4-ZW as energy usage in bar and panel.
- 0000328: Camera Panel when "Remote Access" is selected
- 0000288: SOme scenes can't be saved and disappear.
- 0000274: Modular Alarm Panel - iOs control and Users.
- 0000268: Modular Alarm devices can no longer be selected in Scenes.
- 0000245: no keyboard editting lua scripts via the iPad.
3.517:
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution.
- Added support and debugging for Lua scripts.
- Automatic conversion from graphic block scenes to Lua scripts.
- Added possibility for Lua debugging.
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Power consumption options in block scenes.
- Additional options in video cameras.
- Z-Wave tab in configuration.
- New device inclusion window, informing user of new device configuration stages.
- Helios intercom support
- VoIP panel
- Information top bar and Dashboard - subpage with configurable information views
- New drenchers panel
- Views from cameras in Your Home section
- Possibility to manually add theoretical power consumption for devices not supporting power metering, visible in Energy Panel too
- Support for new device types, new device parameters.
- Modified scenes main screen.
- New Virtual Devices version - now you can add a button or slider executing Lua script.
- Changed configuration interface layout
- Moreover 3000 minor bug fixes and improvements.
  • Answers 102
  • Created
  • Last Reply
Guest Lode
ikillou I've got the same issue with the "Exclude from alarm" option...
What kind of sensors ?
If have that issue with the universal sensor from fibaro.
As you know you the universal sensor can trigger two motionsensors.
The one i use shows properly up.
But the second i don't use and excluded from the alarmsystem keeps showing up BUT only by setting the alarm through ipad app not by UI alarmpanel.
I've seen it with a Universal Binary Sensor...
for me is : Fibaro FGK101 Door/Window Sensor
All good here! Excluded three FGK-101 Door Window sensors and they disappeared from the Alarm panel...
Guest Kuuno
when arming whole house from iphone app then there is no notification. add a ntificatrion like you have "lights on" "lights off"
same for disaming
otherwise very nice!
Guest GG
I have a serious problem with 3.580.
When I try to edit any of my existing scenes, all I see is this.
If I click Save in Add scene in LUA, I see this.
How do I edit my existing scenes?
Regards
Ulf
I do not have the same problem. My scenes edit fine.
Just installed 3.580.
DLink DCS-5222L works now fine on iPad, Android and Windows!
Tried out the Video Gate feature and works fine!
Big step forward again!
Can't wait for the multimedia functionality!
Happy new year!
Guest dsilletti
Great news!
Anyway I am not able to upgrade via home.fibaro.com, when I press Start upgrade button nothing happens, there is a way?
Regards
Domenico
P.S. Happy New Year to Everyone!!!!
Guest GG
I have found out the editing scenes doesn't work with internet explorer 9.
It only displays a selection between nlocks and LUA when trying to edit an existing LUA scene.
Also, the setting "Do not allow alarm to stop scene while alarm is running" displays diffrently in ie9 and chrome, see attached images.
These two images represent the same, existing scene, when viewed in IE9 and Chrome.
Edit - sorry, false alarm, it was my browser problem.
Lauri
I still have the problem that I can't edit my lua scenes / can't edit any scene anymore. When I hit the save button I still got a 403. My alarm is not armed. This is now really enjoying
I have enabled and disabled the alarm, but no luck. I use at the moment 2 door sensors for arming disarming and they work just fine.
Update:
Solution; some AEON LABS motion sensors were suddenly ARMED (and they are excluded in the alarm). Strange how they get armed, because before the update they were never armed.
it would be nice if one could assign the new FGSS001 smoke sensor as the main temperature sensor for a room. Now it doesn't show up as an option in the room configuration panel.
..and on that topic, it would be nice to be able to set the main temperature sensor for a room to be a sensor already assigned to another room, e.g. to share sensors. In my case I have an open floor plan with living room and kitchen but have divided it up in HC to be two logical rooms, but the temperature is always the same...
Maybe allow users in the future to create virtual temperature/light sensors etc (virtual devices complying to some given api), so they could show up in the UI?
Btw, thanks for a great product and a great forum!
Regards /JanG
The update went without any trouble. Editing of scenes is no problem either. The GPS tracking function with iphone is now working (never worked before), with a 5 minute interval it eats through the battery like crazy. I'm going to see if the schedule for the interval brings any change in that, but it kinda defies the point.
The alarm in combination with the new app seems to work much better already. At least it can now be switched on from the app (slide up while on the alarm icon in the home screen armes the alarm directly, slide down and you can disarm it). On a total the alarm still needs a lot of work to become a mature solution, but if you are able to work with lua to some degree, at least the basics seem workable now.
So far no downsides in terms of 403-errors or other problems with the interface as some people report.
after the update when I try to disarm alarm panel,hc2 is asking PIN code,but I didn't set any and is not accepting empty
Which is the default new PIN code or how can it be reset?
emariu, you can do that in access control panel
Update went smooth. So far, I have only come across one error: I can no longer edit the advanced parameters for my AeonLabs 4 in 1 sensor.
When in 3.571 still, I changed parameter 3 to 5 seconds (how long to keep 'state on'). This was for testing purposes.
I'm now on 3.580 and trying to change parameter 3 again. Values remains 5 and it shows an error:
"Last set value: 6undefined" (see screenshot).
Also, when I try to edit the 'Desired value' field (for any parameter), it is as if there is an EndOfLine character in there. Moving the cursor to the left one position will cause the cursor to jump back tot he end of the field right away.
Bug?
Guest jschun
Updated to 3.580 (from 3.571) my HC2 froze unfortunately. After 3 hours it still would not come out of error 503 page. Already send mail to Fibaro support (but weekend so no response of course) After several tries with recovery I got my HC2 back, but all my backups were inaccessible (did not show). After test backup, my 3.571 backups returned to me and I tried to restore. But again my HC2 froze in the error 503 page.
Finally I decided to start from scratch
Recovery, 1.038, 1.040, 1.047, 3.580 and exclude and include 70 devices. I'm at device 10 and I see the following effect.
After adding Fibaro Relay Insert 2 * 1.5 KW my HC2 thinks it is also a temperature sensor and a humidity sensor? Would be nice, but of course they do not work
Excluded the Relay and included. Same effect. Did it for a third time, still same problem.
Anyone any idea how to get rid of the two 'ghost' devices? Deleting them does not work.
Thank!
Go to devices menu and click X for delete. Then do nothing about 1-2minutes and click it again, and wait a little bit more - HC2 should say :deleting devices successful and ghost is gone
Guest jschun
Thanks Lauri but no joy
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> But the Relay also has no configuration option, only a long looooong list of parameters. So I guess I have to exclude it again tomorrow. I'm done for today ...
