WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
Mobile apps fully working with this version:
- iPhone app - version 2.1.1 (available on the App Store),
- Android phones app - version 1.3 (available on the Google Play),
- iPad app - version 1.2 (being reviewed in the App Store, available soon).
3.580
- Testing connection with Satel alarm.
- Faster HC2 booting.
- "Undo" button after predefined alarm scene has started.
- PIN codes added to alarm (warning: PIN code will be reset after this update and has to be set up again).
- Information from Fibaro icon added.
- Entry time and exit time in Fibaro Alarm.
- Excluding sensors from alarm system.
- Excluding devices from events history.
- Possibility of setting sensor as always armed or always disarmed.
- Changes dedicated to mobile apps new versions.
- Importing gateways - information about connected gateways.
- Possibility to change temperarure unit.
- Importing / exporting virtual devices.
- Network settings fixes.
- Virtual devices changes and fixes.
- RGBW device fixes.
- Backups creating fixes.
- Virtual devices update - sleep in main loop increased to 3 seconds.
- Fibaro Alarm fixes and changes (i.e. always armed / always disarmed, multi arming / multi disarming devices, excluding sensors from alarm system, configuring sensors).
- Stopping scenes and blocking saving scenes and devices while alarm is active.
- Fixed searching for other HC2 units in local network.
- Other minor bug fixes.
Bugtracker tickets:
- 0000077: Logi
- 0000141: Włączanie alarmu z iOS
- 0000398: Error uploading .png icons
- 0000413: HC2 show me 0.01 W usage for one fibaro dimmer Turned OFF !
- 0000414: HC2 show me 0 W usage for one fibaro 3k switch Turned ON but 10W declared !
- 0000522: In API field "type" appears twice in properties node, sensor, binary light etc.
- 0000531: Show the scene in interfaces changed to "No" without notification -> scenes not visible in Iphone & Android app.
- 0000585: Device Declared power consumption does not work sometimes
- 0000631: 3.548 json.encode crashes in virtual device
- 0000723: 'modified' field in /api/devices is not updated with new timestamp after device state changed
- 0000742: Add delayed trigger to alarm panel
- 0000757: Extra options for "device kind"
- 0000942: Alarm Panel Problems
3.571
- Minor bug fixes.
3.570:
- New json library in LUA.
- User icons in remote access.
- Z-Wave bug fixes.
- Fibaro FGFS101 Flood Sensor support.
- Importing devices from other HC2 gateways (gateway connections).
- New virtual devices with support for iPad and Android apps.
- Changes dedicated to iPad v1.1 application and new Android application.
- Support for new Fibaro FGR221 Roller Shutter module.
Bugtracker tickets:
- 0000899: Can't turn off potential fire and freeze notifications
- 0000511: SP814 template (broken)
- 0000142: Everspring ST814
- 0000782: After HC2 restart/upgrade the RGBW module is shown as 'On' in GUI
- 0000882: Virtual Device popup
- 0000890: When setting new value for ID of a slider(not tested for other controls) the old ui..value tag in JSON is not removed
3.558:
- RGB panel added.
- Fibaro RGBW Controller support.
- Added notifications (email and in UI) about devices low battery level.
- Support for iPad application and new Android application.
- Added possibility to sort sections, rooms, devices and scenes in configuration interface.
- New Event Panel - TimeLine.
- Possibility to move views in Dashboard.
- Possibility to change the type of binary sensor, e.g. motion sensor to smoke sensor.
- Information about last state change of the sensor (e.g. door).
- Fibaro Alarm panel added.
- Added possibility to reset device energy data.
- New languages: Russian, Danish, Finnish, Chinese.
- Bug fixes in showing and configuring power measurements.
- Bug fix in saving Advanced mode of GPS position reading frequency.
- Bug fix in showing information on the map in Family panel.
- Bug fix in VoIP panel - fixed logging in as system user.
- Z-Wave bug fixes.
- Aeon Labs 4in1 bug fixes (attention, in case of not working properly, device must be re-added to the system).
- Other minor fixes in UI and translations.
Bugtracker tickets:
- 0000080: Cameras do not display in IE10
- 0000200: Can't use a binary sensor as an input for bell push in video gate.
- 0000325: Parameter 42/45 representation of wallplug in GUI messed up
- 0000390: Rooms icon
- 0000419: Brak aktualizacji w zakładce pomieszczenia
- 0000488: fibaro:killScenes(ID) doesn't work
- 0000494: Wrong energy usage descriptions in energy panel
- 0000510: call wakeUpDeadDevice in scene seems not work as expected
- 0000515: Problem w wyznaczenia godziny wschodu i zachodu słońca
- 0000519: decimal points or comma's in variables panel
- 0000550: Don't mark as dead node option not saving
- 0000544: LUA 'Attention' dialog rendering
- 0000545: Improve alarm panel labels used in 'status' drop down
- 0000546: Device name length needs to be enforced when editing
- 0000556: złe tłumaczenie
- 0000590: Energy panel settings tab has a save button
- 0000596: Dashboard General Main sensors show Wrong DEAD
- 0000602: no ptz actions with a foscam like camera
- 0000647: Problems with setting associations
- 0000667: In dashboard view Danfoss thermostats are counted as dead
- 0000673: In General Panel on Dashboard all FGK101 Door/Window Sensors counted as doors even if change device kind to window sensor
- 0000678: fibaro:log not work in devices panel "/fibaro/xx/devices"
- 0000679: Aktualne zużycie energii
- 0000719: Can't use private icons for window sensor
- 0000769: Error message in dasboard
- 0000778: Missing translation
- 0000784: in german translation no values in devices configuration
3.548:
- Changes related to new version of operating system repositories.
3.547:
- Fixed bug related with some cameras problems in remote access mode.
3.546:
- Solved 503 Error issue appearing for some users.
- Fixed working of scenes based on user location.
- Fixed energy graphs in live mode.
- Solved problem with diacritics symbols in devices/rooms/scenes names.
- Other system fixes.
3.545:
- Fixed displaying image from Home Entry System Helios.
3.544:
- Possibility to run scenes by Lili (please reload Lili database in configuration after update).
- Remote access scripts watchdog added.
- Added possibility to choose triggers in block scenes.
Bugtracker tickets:
- 0000487: Add/Delete GPS Points Error.
- 0000480: GPS condition doesn't work.
- 0000476: Panel ogrzewania przestaje.
- 0000460: Heating Linked Device fails to switch off Switch 2 (a.socha) - rozwiązany.
- 0000459: Modified variables don't show up in scenes.
- 0000454: Variables with space can't be changed.
- 0000437: EnergyPanel date select.
- 0000426: Option to deactivate variables as scene trigers
- 0000424: Bad slider position (cosmetic) in dashboard / actuator panel.
- 0000418: Błędne przekierowanie w trakcie tworzenia scen opartych na pozycji GPS.
- 0000403: headline.png not found in linked device panel (head of menu).
- 0000402: Unable to save new state of predefined variable value in dedicated panel.
- 0000396: Belka nazwy panelu domofonu.
- 0000387: Impossible to access the HC2 web page from iPad.
- 0000380: On the HRT4-ZW the temperature reading is being used as an energy reading.
- 0000369: Translation needed: Home Entry System Panel.
- 0000350: uprawnienia użytkownika.
- 0000341: Bad energy costs in energy panel header when switching from power usage to energy costs.
- 0000331: Temp value of HRT4-ZW as energy usage in bar and panel.
- 0000328: Camera Panel when "Remote Access" is selected
- 0000288: SOme scenes can't be saved and disappear.
- 0000274: Modular Alarm Panel - iOs control and Users.
- 0000268: Modular Alarm devices can no longer be selected in Scenes.
- 0000245: no keyboard editting lua scripts via the iPad.
3.517:
- New, quicker and future oriented system architecture.
- Rebuilded, faster configuration interface.
- Faster communication within Z-Wave network. Faster system reaction for devices states changes.
- Improved, much quicker sending commands to devices via the iOS application.
- Quicker scenes execution.
- Added support and debugging for Lua scripts.
- Automatic conversion from graphic block scenes to Lua scripts.
- Added possibility for Lua debugging.
- Sending sms/email/push notification from scenes.
- Integration with Satel alarm.
- Added support for new device types.
- Energy panel and managing devices with energy measurement.
- New, extended mobile interfaces.
- Power consumption options in block scenes.
- Additional options in video cameras.
- Z-Wave tab in configuration.
- New device inclusion window, informing user of new device configuration stages.
- Helios intercom support
- VoIP panel
- Information top bar and Dashboard - subpage with configurable information views
- New drenchers panel
- Views from cameras in Your Home section
- Possibility to manually add theoretical power consumption for devices not supporting power metering, visible in Energy Panel too
- Support for new device types, new device parameters.
- Modified scenes main screen.
- New Virtual Devices version - now you can add a button or slider executing Lua script.
- Changed configuration interface layout
- Moreover 3000 minor bug fixes and improvements.
  • Answers 102
  • Created
  • Last Reply
I don't think setting an icon for a virtual device through the http api is working anymore. Anyone else confirm?
Rob, i don't have any issues with setting an icon in my VD.
Thanks Jonny,
odd I am sending
all other calls are working
What is up? Calling app has not changed?
I must be going mad.
I have another issue.
I have a virtual module that has this in the main loop :
Now I am almost sure that the virtual module lost it's main loop after random amount of time.
This didn't appears on 3.573. This bug has been raized after 3.574/3.575 (when the sleep has been added on the main loop).[/code]
Why use many fibaro:getGlobalValue, you surcharge your HC2 for nothing ?
Why 5 seconds for refresh, is it really worth ?
Try as:
Why getGlobalValue will surcharge the HC2 ? It there something like Mutex under the hood ?
Maybe not / maybe yes. This issue is that before 580 this was working, now, stop at random time with random error.
See
Try as: (...)
Thanks for the hint (was my first VD, so...)
Krikroff, kiwi, if script stop working then you may get nil or damaged json and LUA killing that mainloop
here you got example how to deal with it w/o let LUA to terminate mainloop
Thanks. I have replaced my code with the following :
Hope this will make it more stable. Thanks by the way about the code on how to catch errors or whatever.
By the way is there any good function to replace the variable thismodule=170; by something more dynamic ? like fibaro:thisvirtualmodule() or something nice ? (same question about scene in LUA).
I use "pcall" in many of my scripts for a long time
/emoticons/default_icon_biggrin.gif" alt=":-D" /> , this function should be used by all to prevent breaks in lua code execution and avoid unmanaged behavior
So I will change my code to try also, but must change many things
/emoticons/default_biggrin.png" alt=":D" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />.
I will make some test tonight I try .
[ Added: 2014-01-15, 14:50 ]
So now the main loop continue, but give me error on every loop.
So that is just a part off the solution.
Would be great to have a code to reload the main loop.
Replying to myself.
Issue still there.
See code before... Now I have in log :
"ECOdevice polling failed"
Until I press save again.
Seems that json.decode gets fucked and cannot repair itself.
No need option to restart main loop.
Would be great if the main loop was not a loop but a script that auto starts.
Loop is ok for me. But we must have an option to reload if bug.
@kiwi
You can use 'fibaro:getSelfId()':
but sadly these do not work
Since 3.580 update it's two time that HC2 freeze and does not respond anymore (no web or app connection). The web interface show the background, side and main menu but every page is "empty".
HC2 respond to ping and port 22 (ssh) is still open.
The only way to recover is to press the shutdown button on hc2 once and wait until all the led fade off and start it again with the same button.
I really need a fix, soon! Please Fibaro, help me!
That happen to me when I play with json file from main loop and Try to connect ipad
@Shad: I have "mostly" isolated the issue. This Net.FHttp that breaks and doesn't seems to "clean" itelf until there is reload of the virtual module. Very bad
Create a button, put your code inside.
Don't forget to use pcall function to be sure error don't block your code.
And call button fro main loop. Works great for me.
Hi robert
try and tell me
br,
