I'm at my wits end with this - after months of research, I am no closer to a z-wave doorbell solution that is practical.
I have a Fibaro door sensor, linked to a bell push - so far so good.
When the bell is pushed it flashes the Philips Hue lights in my hallway - instantaneous and effective if you happen to be looking.
However, I need a sound to be made as well (the bell bit).
Everspring TSE03 doorbell set is useless (although the bell chime does work in Homeseer, it does not in HC2).
Sonos text to speech is so slow as to be pointless and doesn't really grab your attention enough.
Ideally, I'd like to link the TSE03 to work in HC2 as it does in Homeseer - but no luck so far. There doesn't seem to be anything else available on the market taht would work.
Any ideas/thoughts?
Can you use a siren, and then make a scene that turns it off 1 second after it starts? And to dampen the "siren-sound" you can muffle it in several different ways.
What about using a normal door bell, combined with the Fibaro universal binary sensor? I understand that a normal doorbell runs on 8V and the sensor can do the same. Hook things up so that your normal doorbell always works, the Z-Wave sensor is extra free bonus.
You don't really say it, but you could read in your post... that the UBS would control the doorbell. But the UBS is a sensor, not a relay. The outputs always follow the inputs and the outputs cannot be controlled remotely. Just saying this for the people who don't own a UBS yet
/emoticons/default_icon_wink.gif" alt=";-)" /> And all the owners already know: "damn, can't control the outputs..."
You can use TSE03 Doorbell to give sound.
Just add bell unit (3 clicks) and then use lua.
example.
fibaro:call(204, "setValue", "255")
Where 204 is bell ID.
Works for me.
    example.
    Works for me.
    Thanks - that was exactly what I was looking for - will try when I get home!
    Paul
    [ Added: 2014-01-14, 18:55 ]
    Brilliant - this works a treat!
    It's only taken me three years since I purchased the TSE03 to find a use for it!
    Guest deraaij
    example.
    Works for me.
    Paul
    Do I understand it correctly the doorbell unit works (if used as stated above) but the ever spring pushbutton is still a no go?
    Yes, pushbutton is useless.
    for me, it's tricky to get bell included. Have to reset and try to include many times.
    Just keep HC in learning mode and start clicking. Finally hc sees it.
    Guest deraaij
    Thnx!
    I have a normal wireless doorbell (Friedland D911S) with a Fibaro Universal sensor connected between the bell push and the NO contacts of the doorbell. When the bell is pushed, you hear the doorbell, my Hue lights flashes, and I get a push message. Works perfect.
    • 2 months later...
    The best solution is to use a FGS221 for the bel.
    I have build a compleet solution using
    FGS221 + friedland
    With this solution i can even decide to switch to the silence mode when ever needed.
    if you are interested let me know.
    FGS221 + friedland
    I am interested
    I use the FGK in combination with a Jacon Jensen doorbell 2. I had to solder 2 wires to the doorbell button, connected the wires to the FGK and configured the FGK as motion sensor and parameter 3 to INPUT_NO.
    Works perfect.
    FGS221 + friedland
    I am interested
    Will post some pictures
    Using FGS221 + relay switch + 12v adapter all integration in a box
    for the dutch users i have compleets solution in my shop
    My doorbell botton is connected to the binary sensor at when its breached it sends a notification on my phone. and if alarm is armed and doorbell is pushed it takes a picture from front door and sends notification.
    Thats how i done it
    i want it powered like TANE so looking forward to details
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />))
    FGS221 + friedland
    Hi Tane
    I too would really like to see this solution. I have had a look at your site with the help of Google Translate but cant find anything.
    This is the final product.
    I have connected to different bell systems to the control. One is timer based the other one will ring always.
    thechnical info will fallow later.
    for the Dutch users ..its here with 3 different options.
    Connection
    1-2 is input (from outside)
    3-4 always ring
    5-6 event based ring
    Impressive
    I made a crude mod to the Everspring Door bell after giving up trying to pair.
    Open up the bell module and solder two fine wires to the contact inside and link to the wired bell push. This works ok only downside is the Tone changes at every press but at least it works and i get the push notification.
