Update 3.590
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
Mobile apps fully working with this version:
- iPhone app - version 2.1.1 (available on the App Store),
- Android phones app - version 1.3 (available on the Google Play),
- iPad app - version 1.2 (available on the App Store).
3.590
- Optimized for remote access activities.
- Support for Fibaro Motion Sensor.
- Fibaro Alarm minor fixes.
- Gateway Connections improvements.
- Z-Wave engine improvements.
- Other minor bug fixes.
3.580
- Testing connection with Satel alarm.
- Faster HC2 booting.
- "Undo" button after predefined alarm scene has started.
- PIN codes added to alarm (warning: PIN code will be reset after this update and has to be set up again).
- Information from Fibaro icon added.
- Entry time and exit time in Fibaro Alarm.
- Excluding sensors from alarm system.
- Excluding devices from events history.
- Possibility of setting sensor as always armed or always disarmed.
- Changes dedicated to mobile apps new versions.
- Importing gateways - information about connected gateways.
- Possibility to change temperarure unit.
- Importing / exporting virtual devices.
- Network settings fixes.
- Virtual devices changes and fixes.
- RGBW device fixes.
- Backups creating fixes.
- Virtual devices update - sleep in main loop increased to 3 seconds.
- Fibaro Alarm fixes and changes (i.e. always armed / always disarmed, multi arming / multi disarming devices, excluding sensors from alarm system, configuring sensors).
- Stopping scenes and blocking saving scenes and devices while alarm is active.
- Fixed searching for other HC2 units in local network.
Bugtracker tickets:
- 0000077: Logi
- 0000141: Włączanie alarmu z iOS
- 0000398: Error uploading .png icons
- 0000413: HC2 show me 0.01 W usage for one fibaro dimmer Turned OFF !
- 0000414: HC2 show me 0 W usage for one fibaro 3k switch Turned ON but 10W declared !
- 0000522: In API field "type" appears twice in properties node, sensor, binary light etc.
- 0000531: Show the scene in interfaces changed to "No" without notification -> scenes not visible in Iphone & Android app.
- 0000585: Device Declared power consumption does not work sometimes
- 0000631: 3.548 json.encode crashes in virtual device
- 0000723: 'modified' field in /api/devices is not updated with new timestamp after device state changed
- 0000742: Add delayed trigger to alarm panel
- 0000757: Extra options for "device kind"
- 0000942: Alarm Panel Problems
  • Answers 87
  • Created
  • Last Reply
Did the upgrade, so far as i can see now, its stable
Everything working fine for me. Thanks for the update
Guest Sander
Every single time I do a stable update, my HC2 gets stuck. (All lights lit). Only after unplugging and pluging it back in again, multiple times it runs again. Last two updates I could live with it, but now i'm done with it.
Same scenario for me. I had to restart 12 times, unplug several times for the box to restart. All led were lit
Did you wait enough? I have 2 boxes and the second one did goes much faster then the first one.
Depends on how much device, scenes, virtual devices you have.
Guest shapa
HC2 boots, but all z-wave devices are not working (information received but no control).
Stable? Ha-ha.
Guest Sander
I have a ferry humble house, 10 dimmers 5 sockets expand a HRT thermostat. Not that much. Waited a long time. Nothing!
Guest azevenhuizen
Problems here as well.
System is stuck in "Update in progress" and the stating "Upgrade Error: 6"
Only option is unplugging and rebooting, but then the system falls back on old firmware and the above loop repeats.
Any way to reset the loop, expect by making a complete restore?
With about 30 devices
it took less than 5 minutes to upgrade from 3.583 beta.
I waited +-45 minutes after clicking START. then as all the led were lit blue for all that time I decided to shutdown the box and then had to try 12 times before it restarted.
Now the box is restarted for 21 minutes. It was first very fast and very reactive for +-3 minutes then it became very very slow and unresponsive for 15 minutes and now all seems to work like before, not very fast but fast as usual.
Guest Sander
Upgrading seems to go just right. After installing and rebooting it gets stuck.
    azevenhuizen, error 6 = try again, disconnect from downloading files
    Sander, gomba777, when all leds lit mean that system is not starting, if after unplugging power and plugging it again you still got that error mean that is something wrong with system then you gonna need do recovery. If you gonna have all leds lit Hc2 gonna have go back to us
    shapa, recover backup and later check do you got unconfigured devices. If you gonna have still problem please contact with our support [email protected]
    edit gomba777 that can be warning before bigger crash contact with support
    Updated my HC2 with no problems. At first it seems my android app had delay but going to wifi it was fast and smooth. No problems here.
    How many backups do you have - who have trouble with update?
    How can so many people doing the same thing get so many different answers.
    For me this time 100% OK.
    Fast install and rebooted all by itself. All working.
    97 nodes 165 devices 60 scenes 14 virtual devices
    confused
    Guest Sander
    Still all light are lit and no recovery. Very disappointed! Contact my vendor tomorrow but I don't think I have any warranty on it anymore. How to proceed if not?!
    Sander, contact with [email protected] and talk with them
    Update work fine for me too.
    Less than 5mn, reboot and work like a charm.
    88 devices, 37 scenes, 8 virtual devices.
    Guys, I upgraded to the 3590, lasted less than 5 minutes and everything went ok.
    Fibaro Well guys, keep it up.
    Only two requests, completed the module alarm and location for iPad.
    Me too update went well around 5-10 min, restart of the box by it self and now everything work fine. Thx
