Update 3.590
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
Mobile apps fully working with this version:
- iPhone app - version 2.1.1 (available on the App Store),
- Android phones app - version 1.3 (available on the Google Play),
- iPad app - version 1.2 (available on the App Store).
3.590
- Optimized for remote access activities.
- Support for Fibaro Motion Sensor.
- Fibaro Alarm minor fixes.
- Gateway Connections improvements.
- Z-Wave engine improvements.
- Other minor bug fixes.
3.580
- Testing connection with Satel alarm.
- Faster HC2 booting.
- "Undo" button after predefined alarm scene has started.
- PIN codes added to alarm (warning: PIN code will be reset after this update and has to be set up again).
- Information from Fibaro icon added.
- Entry time and exit time in Fibaro Alarm.
- Excluding sensors from alarm system.
- Excluding devices from events history.
- Possibility of setting sensor as always armed or always disarmed.
- Changes dedicated to mobile apps new versions.
- Importing gateways - information about connected gateways.
- Possibility to change temperarure unit.
- Importing / exporting virtual devices.
- Network settings fixes.
- Virtual devices changes and fixes.
- RGBW device fixes.
- Backups creating fixes.
- Virtual devices update - sleep in main loop increased to 3 seconds.
- Fibaro Alarm fixes and changes (i.e. always armed / always disarmed, multi arming / multi disarming devices, excluding sensors from alarm system, configuring sensors).
- Stopping scenes and blocking saving scenes and devices while alarm is active.
- Fixed searching for other HC2 units in local network.
Bugtracker tickets:
- 0000077: Logi
- 0000141: Włączanie alarmu z iOS
- 0000398: Error uploading .png icons
- 0000413: HC2 show me 0.01 W usage for one fibaro dimmer Turned OFF !
- 0000414: HC2 show me 0 W usage for one fibaro 3k switch Turned ON but 10W declared !
- 0000522: In API field "type" appears twice in properties node, sensor, binary light etc.
- 0000531: Show the scene in interfaces changed to "No" without notification -> scenes not visible in Iphone & Android app.
- 0000585: Device Declared power consumption does not work sometimes
- 0000631: 3.548 json.encode crashes in virtual device
- 0000723: 'modified' field in /api/devices is not updated with new timestamp after device state changed
- 0000742: Add delayed trigger to alarm panel
- 0000757: Extra options for "device kind"
- 0000942: Alarm Panel Problems
  • Answers 87
  • Created
  • Last Reply
No, fortunately it has started normally.
Guest Lode
Fast update, running smoothly
HC2 with 222 devices updated and works flawlessly...
3.548 -> 3.590 updated two days ago without any problems so far, took about 5 minutes.
After 24 hours i have so much dead nodes never before, 50%
/emoticons/default_icon_evil.gif" alt=":evil:" />
4 Times reboot and now yet 30 % dead nodes.....and they do not wake up...
AlexM, please contact support ([email protected])
After multiple reboots and restart it works, so far......
I hope it works now, if not and the same problem comes back i contact the support.
thanks for info
Guest Sander
thanks for info
Same here, unplugged it Wednesday plugged it back in today and now it works. Still! This was the 3rd time. This time it was extreme. Want to know how this is possible.
    Sander, by restart you are clening zwave buffor that mean you got a heavy traffic
    Guest Sander
    A.Socha, thanks for you're replay, I can agree I have a ferry humble house around 6 dimmers 4 power sockets and a HRT. I have rebooted the hc2 multiple times unplugged it, waited 10 mins and plugged it back in again. Only today after a day of no power it worked again. Strange right. Happy it worked agin but I'm afraid for the next update.
    Sander, try to optimize that traffic, support can you help with that
    When I switch ON one light i wait 2 minutes. And when i started the start the update of my z-wave i wait a long time and the process don't finish.
    Hi Fibaro users,
    since the upgrade my wall plug led is always off (before upgrade, color was changing according to power comsumption)
    When I turn on the plug, it briefly shows a white light and then the light goes OFF.
    The plug delivers power to connected device but no light is showing anymore
    Anyone to confirm that behavior change ? Configuration still shows that the Light should track power usage but it doesn't do so anymore.
    Chtristophe
    Hold down B-button for 2-3sec, this brings back the lights
    Guest jschun
    Previous upgrade made my HC2 Fubar and I had to start from scratch. Now I updated (a little scared) from 3.580 to 3.590 and it took my HC2 2 hours to come out of installation mode. But everything looked okay.
    Until now, the HC2 is no longer responding via browser. I will reboot it, hope it will help
    I personally think that the update technology must be first addressed Fibaro Group. It is to unstable if you ask me ... It takes the fun right out of my domotica hobby. adding 90+ devices again is not fun!
    [update] Rebooted 3 times, no joy ... took HC2 off power for 15 minutes, booted and it works (for now). Only all my self made icons are gone somehow ... Another reboot got them back.
    All and all: update took more than 2 hours, 6 reboots and a cold boot and another reboot did the job. For now at least ...
    jschun, please contact with support can something be wrong with your hc2
    @Lauri,
    Thank you for the hint, it did the trick. Strange that it occured with the upgrade.
    Christophe
    Started the upgrade in google chrome but got error everytime and had to reboot the server. In IE everything worked after refreshing the browser.
    Updated 5 days ago and everything working fine for me, my HC2 is very fast ans stable : thank you very much Fibaro
    +1 I also noticed a stability in the last version and even some perfomance boost. I guess a big work was done. Thank you, Fibaro!
