Step-by-step guide for a factory reset?
Tried to update my Fibaro HC2 but something must have gone wrong as I cannot get in contact with it any more. And Fibaro Finder cannot find it either. I have tried to reset the device, but still I cannot find it. This might be owing to the fact that my internal IP-address range is from 192.168.10.01??? And it might be the case that the HC2 resets to another IP-adress range??? If so, I would be really grateful if someone could walk me through the necessary steps in order to get it back! Or point me to a manual where this is thouroughly explained. Thanks!
[ Added: 2014-07-30, 00:06 ]
I have tried to disconnect the power plug and before plugging it back in, I have held down the recovery button. This makes all blue LED starts flashing, and then one by one they get a static blue light. When all lights are static, I have released the recovery button. Fibaro Finder still cannot find the device, and I cannot connect through web browser with local ethernet cable and ip address set to 192.168.81.1 in the web browser and static ip address set on PC to 192.168.81.5
What am I doing wrong?
If that fails contact support, such LED state may be caused by damaged recovery stick.
