Update HC2 4.020 BETA
Fibaro Home Center 2 v 4.020 BETA.
Beta version is designed for user testing and soon will be released as official.
WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
4.020:
New Features:
Pre-Update Confirmation - installing update on 4.020 or newer will prompt user additional confirmation.
Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network
Fixed Issues:
Incidental marking devices as dead
Horstmann Devices support
Many other Z-Wave engine fixes
Known Issues:
Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
Important! Remote access is NOT available for this version.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Previous:
Breached senser with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Plugin for Sony TV will not work with newest Sony Firmware
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
4.019:
New Functionalities:
- Configuration > Backup now is Backup & Recovery
- Recovery Memory Status - can be checked on Backup & Recovery
- Backups - information about compatibility with current HC version
Resolved Issues:
#0001359: For some reason 1 smoke sensor doesnt show black box info.
#0001524: 3.902 Alpha - HUE plugin won't create new user
#0002037: Cannot delete device, but after a restart the devices shows as being deleted
#0002048: JSON ENCODE / DECODE doesn't work properly
#0001920: [ERROR] 09:23:47: line 44: attempt to index global 'json' (a nil value)
#0001699: panel energii
#0001849: Fibaro Door and Window Sensors do not report
#0001852: Unable to delete devices
#0001861: Since upgrading no scenes work
#0001877: HC2 stops working on 4.017
#0001709: When adding Foscam generic camera to plugin the password field is misspelled "Passwrod" should be "Password"
#0001824: Aeon Switch with energy meter. No more energy measurement/logging after upgrade to 4.017 beta.
#0001935: Notification of the battery status
#0001963: Event panel refreshed while browsing
#0001869: Fast scrolling in event history
#0001894: Log messages do not span columns
#0001655: Changing pages results in spinning wheel
#0001815: Power calcutaion is only working in rooms with Fibaro Wall plugs
#0001790: Virtual Device icon change causes a crash
#0001834: Get error 502 and 503 after virtual device import
#0001701: Controlled device is set to Air Conditioner on dimmers
#0001962: UI crashed after creation of magic scene
#0001966: setting " How frequently GPS position from the user?s iPhone should be collected" is not saved after reboot hc2
#0001888: Execution of lua commands
#0001907: Danalock POL_ZES100 (Z-Wave Danalock Square) sowing but not functional
#0001596: universal sensor has not the normal picture and dallas 18b20 temp does not work
#0001652: uni bin sensor breach scene does not work
#0001548: Nie działa triger włączenia włącznika Duwi
#0001812: HC2 doesn't respond anymore
#0001593: Email address validation wont allow + to be used
#0001651: HTML special characters being displayed in Virtual Device code
#0001946: fibaro:getSelfId does not work
#0001889: Unable to debug slider code
#0001992: FGK-101 with a DS18B2
#0002005: After creation of a magic scene i'm unable to login to the fibaro home center (keeps loading)
#0002023: Disarm sensors with scene
Known Issues
- Breached sensoer with Arm Delay causes instant alarm after being armed
- Data range selection in event panel doesn't work properly
- For devices imported via Gateway Connection may have no icons
4.018:
Resolved Issues:
#0001566 All versions of FIBARO cannot support the switch state to return to the "Multilevel Switch Command Class, version 2"
#0001576 Untranslated text in Satel input/zone page
#0001578 Cannot change label value
#0001618 HSP02 no longer has parameters
#0001624 no different color for slave devices
#0001630 Reconfiguration did not run on a dimmer, resulting in no "sceneactivation"
#0001631 Roller Shutter 2 scene won't close
#0001711 Danfoss LC13 and older model are dead or E5 on the Danfoss itself
#0001773 Danfoss LC13 no Icon displayed
#0001747 Weather display wrong place
#0001834 Get error 502 and 503 after virtual device import
#0001836 Lili
#0001853 After upgrade web interface is slow when changing views
#0001873 No push messages possible on iPad/iPhone with 4.017
#0001880 Not able to set Variable manually anymore
many other fixes
Known Issues:
- Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
- Important! Remote access is NOT available for this version.
- Gateway Connection - status of dead device between master and slave controller may be different
- Devices not properly configured on 3.X may not be converted properly
- Reconfiguration may not work properly in some cases
- On mobile clients devices may be visible in different categories than configured
- Advanced settings for some imported devices may not work properly
- Plugin for Sony TV will not work with newest Sony Firmware
- Event Panel- some issues with scrolling
- LUA functions fibaro:log("") i fibaro:call(id, "setproperty", "") may have some issues
- Horstmann Switch HRT4-ASR-ZW is not fully supported
- Horstmann Thermostat HRT4-ZW- higher battery usage and incorrect reports in some cases
- Doorlocks- some functions may not work properly
- Thermostats Setpoint- are not fully supported
4.017:
New functionalities:
User's Plugin Installation - ability to build and install Home Center plugin
FGHC Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Added support for American English (EN-US)
Plugins:
Nest - plugin for well-known thermostat
Netatmo - plugin for thermostat and weather station from netatmo
3.907:
This version mainly concentrate on adding better support and integration for more devices (not only z-wave device).
Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.
New Home Center software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards like TCP/IP, IR*, RS 232*, UPNP. Plugins have their own user interface and can call all APIs available on HC2. Possibility of building plugins by independent developers will be introduced in next versions.
* required additional hardware.
New functionalities
Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
Magic Scenes - new, simplified and easy to use graphical way to create scenes based on condition > action flow.
Temperature Panel - allows to see history of temperature changes in rooms and on each device.
Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
Z-Wave Door Locks support - controlling and PIN settings.
Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts at iPad and Web Page. Sensitivity level is now easier to set.
Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
Device hiding - device that is not in use can be hide without removing it.
Device deactivation - deactivated device is visible in UI but can't be controlled.
Multithreading added for HC (server and z-wave) - now engines work much faster.
Event panel moved - for better usability now is available in menu on right side of screen.
User rights management - moved to Configuration.
Block Scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
Lua Scenes - updated tooltips for devices.
Plugins:
Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
Plugins search
Network devices search via ARP
Plugins category Safety:
DSC Alarm - for DSC Alarms,
Helios Basic - integration using Basic license,
Helios Gold - integration using Gold license
Mobotix - for Mobotix videophone,
Satel Alarm - for SATEL
Plugins category Cameras
more than 100 devices from various manufacturers
Plugin category Climate
Carrier Furance
WS Davis Vantage
Plugins category Multimedia
LG Bluray
LG TV
NC + mediabox
XBMC Remote Control
Denon Amplifier
LG Bluray
Onkyo Amplifier
Philips Bluray
Pioneer Amplifier
Samsung TV
Sonos
Sony Bluray
Sony TV
Plugins category Other
Philips Hue
Wake on LAN
Other changes
Many other improvements to the system
Users who use version alpha from 3.901 to 3.906 need to perform recovery first and update from 3.590 after restoring backup.
  • Answers 111
  • Created
  • Last Reply
Any more details of what that does? edit: OK just a UI for the existing feature.
Do I need to add and remove horstmann to get fix?
OK
On Horstmann ASR
Go to main device
Un-check Hide device. Save.
Go back into main device
Reconfigure Device
Reset any associations from control
This works but creates new ID anyway. . Tried reconfigure from slave and it failed.
The fix-list of this 4.020 caught my attention. So I upgraded from my running 4.019. That version had many, many nodes marked as dead. And they were still marked dead after the upgrade. So I clicked on them and 1/2 hour later I still have 0 dead devices. I ran a quick test (android client, scripts both manual and automatic, web interface) and all went well. Note: I did not start from my 3.5 version so I can't comment on the bugs I've found going from that version to 4.019.
Some moments after I wrote this, my "Danfoss Living Connect Thermostats" were marked dead. When I push the middle button of the thermostat, the device becomes undead, but a bit later dead again...
Some moments after I wrote THAT, my "Danfoss Living Connect Thermostats" were ... alive again.
Now I am confused!
Thanks Fibaro Team,
this is the way it should be, send small bugfixes out there, so you know if its working and all of your users will see, that there is development and fixing from side of fibaro. I hope you will continue this ... sending updates more frequently!
Best wishes, will try today 4.0.20 and report
Thanks Fibaro Team,
+1 could not agree more!
Thanks Fibaro Team,
Agree.
4.019 was the först version ever that I considered usable. But with annoying bugs. (Since every pre 4 release had the annoying things-become-temp-sensors)
4.020 appears tips be , well, simply useable.
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />. (For ME that is.. I am sure there are still crippling bugs formtpothers)
Buuuut, can Finaro continue on this path?
Guest Lode
Still same dead nodes......
/emoticons/default_icon_evil.gif" alt=":evil:" />
Did you click on the dead nodes? If not... well... I also expected them to be un-dead after upgrade... But apart from Danfoss (sometimes), my devices are still alive.
sure they are dead?
might just be very sleepy?
Guest Lode
Yes, i did but as i mentioned before, they do work.
They are only marked as dead.
[ Added: 2014-11-28, 17:59 ]
sure they are dead?
They have had enough time to rest
This still shows nothing usefull...
Oh! Yes! I completely forgot about that strange looking window stuck at "0"... that's what you mean?
I saw that too. I closed my browser and reconnected, right on time to see the download was already complete and it was installing.
I assume this is a bug in the 4.019? Because it's that version that is spawning this window?
Yup, there's a bug in the update window. Just close that one and open a new one will display the progress bar.
CO2 Siegenia Aubi now Working !
Aeon Labs Energy Monitor still not
Davis Vantage Plugin not Working (no refresh after startup)
Otherwise no problem at this moment
trying tomorrow delete and add Energy monitor
Anybody Noticed that when you try and get values using lua from universal binary sensor ( in my case temperatures ) you get very very wrong values ??????
meaning
temp=fibaro:getValue(80, "value")
fibaro:debug("current Tank temp "..temp);
what i get from debug is 20
what my actual reading from the sensor is 53
After update from 3.590 to 4.020, all my devices are inoperate. No communication between user interface to all devices.
I launch configure for all devices and not working to.
Help me please
Guest spazpeker
My Horstmann Thermostat HRT4-ZW do not work so I deleted one and its receiver and added them again
They now both seem to look right and respond however when I associate the receiver it does not save the association
Anyone else having the same problem ?
meaning
Correction yes same here. Was looking at another type of temp sensor by mistake. All universal are same as yours.
But now you look deeper it is random....
[ Added: 2014-11-28, 19:18 ]
Just about to report that.
Also while the association to controller works so changes on dial are picked up in device, I can not set setpoint through fibaro device.
Just going to check the api.
Checked that now and api changes value but device does not show waiting for wakeup. I am going to guess it will not actually set.
I think bug needs to be opened again.
Now after having 4.0.20 running for some hours, everything ok till now ... no dead nodes.
so horstmann not fixed and universal sensor temperature broken.
danfoss latest version broken
