Ijuk 1
I wish to create a scene where an Aeon Multisensor detects motion, and given that the light is low enough will switch on a relay to switch on a ceiling light.
The scene worked for 2 days, but the multisensor lost configuration and since the scene has not worked. Please help I am not sure what I am doing wrong
I have created 2 scenes
The on scene:
Motion sensor: Aeon == Breached [ ] 0 s and light sensor
< on 130 [0] s
Then
Porch Light Relay = Turn on 120 [0] s
The Off scene:
Motion sensor: Aeon == Safe [ ] 150 s
Then
Porch Light Relay = Turn Off [ ] 0 s
Aeon
Advanced
Node ID: 2
Z-Wave protocol type: 6
Z-Wave protocol ver.: 3.28
Wake up interval (s): 720
Polling time interval: 360
Do not mark as dead: No
Notify when battery low via e-mail
Show energy consumption measurements
Clear historical energy data
Clear
Use template for parameters
Save logs to Event Panel
Alarm settings
Sensor is excluded from alarm system
Sensor is armed with delay or it will trigger the alarm after some delay
Sensor arming conditions
Here you can specify conditions that must be met in order to arm the sensor. Use this function if you want sensor arming dependant on other devices states (eg, if the blind closed).
Alarm mode:
Normal
Always armed
Always disarmed
automatically force device state at arming
Normal mode means that you can arm or disarm device via interface, scenes or virtual devices (lua).
Room Name Type Required state
Porch Motion Sensor Aeon Motion Sensor Safe
Add or remove device
Device description
Associations
Configuration
Reconfigure device
Reload parameters
Number Data Type Desired value Current value
2 1d 0 0
3 2d 10 10
4 1d 1 1
5 1d 1 1
101 4d 224 224
102 4d 1 1
103 4d 0 0
111 4d 300 300
112 1d 300 300
113 4d 4 4
6 answers to this question
