Update HC2 4.022 BETA
Fibaro Home Center 2 v 4.022 BETA.
Beta version is designed for user testing and soon will be released as official.
WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
4.022:
New Features
Remote access is available for this version.
Resolved Issues
#0001513 RGBW custom created programs
#0001640 sceneActivation trigger doesn't seem to work
#0001681 Add / remove device continuous loop
#0001772 the remote control (KFOB2) we as a dimmer in Fibaro HomeCenter2 indicated
#0001898 Greenwave 6-socket plug shows as 7 switches
#0001924 beta 18 can not save scene with lux as a trigger (fibaro pir)
#0001931 HRT4 ASR UNIT not work in the Version 4.xxx
#0002000 Danfoss LC13
#0002032 Danfoss LC13 marked dead moments after status shows as "device is awake"
#0002081 FGRGBWM-441: Cannot turn on/off using mobile applications
Fixes for Z-Wave locks (Yale, FollowGood, Schlage)
Fixes for Z-Wave thermostats
Fixes for 3.x -> 4.x conversion process
Issue with backup compatibility
Known issues
Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Plugin for Sony TV will not work with newest Sony Firmware
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
4.021:
Resolved Issues:
#0001844 HRT4-ZW and ASR-ZW not working, causing the heating system to burn continously
#0002026 SSR-303 not properly recognize
#0001958 After recovering backup all devices where online. Now all battery devices has become dead
#0002095 After upgrade V3 to 4.019 random dead nodes appear
#0002087 Nodes marked as dead, but functioning.
#0002036 Wrong spelling in Delete Device window: "Learing" instead of "Learning"
#0002139 4.020 Horstmann hrt4 can not set association
incorrect values returned by fibaro:getValue (LUA)
Horstmann Thermostat HRT4-ZW does not save the association
Many other minor fixes
4.020:
New Features:
Pre-Update Confirmation - installing update on 4.020 or newer will prompt user additional confirmation.
Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network
Fixed Issues:
Incidental marking devices as dead
Horstmann Devices support
Many other Z-Wave engine fixes
4.019:
New Functionalities:
- Configuration > Backup now is Backup & Recovery
- Recovery Memory Status - can be checked on Backup & Recovery
- Backups - information about compatibility with current HC version
Resolved Issues:
#0001359: For some reason 1 smoke sensor doesnt show black box info.
#0001524: 3.902 Alpha - HUE plugin won't create new user
#0002037: Cannot delete device, but after a restart the devices shows as being deleted
#0002048: JSON ENCODE / DECODE doesn't work properly
#0001920: [ERROR] 09:23:47: line 44: attempt to index global 'json' (a nil value)
#0001699: panel energii
#0001849: Fibaro Door and Window Sensors do not report
#0001852: Unable to delete devices
#0001861: Since upgrading no scenes work
#0001877: HC2 stops working on 4.017
#0001709: When adding Foscam generic camera to plugin the password field is misspelled "Passwrod" should be "Password"
#0001824: Aeon Switch with energy meter. No more energy measurement/logging after upgrade to 4.017 beta.
#0001935: Notification of the battery status
#0001963: Event panel refreshed while browsing
#0001869: Fast scrolling in event history
#0001894: Log messages do not span columns
#0001655: Changing pages results in spinning wheel
#0001815: Power calcutaion is only working in rooms with Fibaro Wall plugs
#0001790: Virtual Device icon change causes a crash
#0001834: Get error 502 and 503 after virtual device import
#0001701: Controlled device is set to Air Conditioner on dimmers
#0001962: UI crashed after creation of magic scene
#0001966: setting " How frequently GPS position from the user?s iPhone should be collected" is not saved after reboot hc2
#0001888: Execution of lua commands
#0001907: Danalock POL_ZES100 (Z-Wave Danalock Square) sowing but not functional
#0001596: universal sensor has not the normal picture and dallas 18b20 temp does not work
#0001652: uni bin sensor breach scene does not work
#0001548: Nie działa triger włączenia włącznika Duwi
#0001812: HC2 doesn't respond anymore
#0001593: Email address validation wont allow + to be used
#0001651: HTML special characters being displayed in Virtual Device code
#0001946: fibaro:getSelfId does not work
#0001889: Unable to debug slider code
#0001992: FGK-101 with a DS18B2
#0002005: After creation of a magic scene i'm unable to login to the fibaro home center (keeps loading)
#0002023: Disarm sensors with scene
4.018:
Resolved Issues:
#0001566 All versions of FIBARO cannot support the switch state to return to the "Multilevel Switch Command Class, version 2"
#0001576 Untranslated text in Satel input/zone page
#0001578 Cannot change label value
#0001618 HSP02 no longer has parameters
#0001624 no different color for slave devices
#0001630 Reconfiguration did not run on a dimmer, resulting in no "sceneactivation"
#0001631 Roller Shutter 2 scene won't close
#0001711 Danfoss LC13 and older model are dead or E5 on the Danfoss itself
#0001773 Danfoss LC13 no Icon displayed
#0001747 Weather display wrong place
#0001834 Get error 502 and 503 after virtual device import
#0001836 Lili
#0001853 After upgrade web interface is slow when changing views
#0001873 No push messages possible on iPad/iPhone with 4.017
#0001880 Not able to set Variable manually anymore
many other fixes
4.017:
New functionalities:
User's Plugin Installation - ability to build and install Home Center plugin
FGHC Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Added support for American English (EN-US)
Plugins:
Nest - plugin for well-known thermostat
Netatmo - plugin for thermostat and weather station from netatmo
3.907:
This version mainly concentrate on adding better support and integration for more devices (not only z-wave device).
Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.
New Home Center software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards like TCP/IP, IR*, RS 232*, UPNP. Plugins have their own user interface and can call all APIs available on HC2. Possibility of building plugins by independent developers will be introduced in next versions.
* required additional hardware.
New functionalities
Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
Magic Scenes - new, simplified and easy to use graphical way to create scenes based on condition > action flow.
Temperature Panel - allows to see history of temperature changes in rooms and on each device.
Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
Z-Wave Door Locks support - controlling and PIN settings.
Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts at iPad and Web Page. Sensitivity level is now easier to set.
Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
Device hiding - device that is not in use can be hide without removing it.
Device deactivation - deactivated device is visible in UI but can't be controlled.
Multithreading added for HC (server and z-wave) - now engines work much faster.
Event panel moved - for better usability now is available in menu on right side of screen.
User rights management - moved to Configuration.
Block Scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
Lua Scenes - updated tooltips for devices.
Plugins:
Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
Plugins search
Network devices search via ARP
Plugins category Safety:
DSC Alarm - for DSC Alarms,
Helios Basic - integration using Basic license,
Helios Gold - integration using Gold license
Mobotix - for Mobotix videophone,
Satel Alarm - for SATEL
Plugins category Cameras
more than 100 devices from various manufacturers
Plugin category Climate
Carrier Furance
WS Davis Vantage
Plugins category Multimedia
LG Bluray
LG TV
NC + mediabox
XBMC Remote Control
Denon Amplifier
LG Bluray
Onkyo Amplifier
Philips Bluray
Pioneer Amplifier
Samsung TV
Sonos
Sony Bluray
Sony TV
Plugins category Other
Philips Hue
Wake on LAN
Other changes
Many other improvements to the system
Users who use version alpha from 3.901 to 3.906 need to perform recovery first and update from 3.590 after restoring backup.
  • Answers 107
  • Created
  • Last Reply
hi guys,
I have updated my HC2, and re-included my PowerNode Greenware, everything works fine but no information about the consumption / only in "kWh". that is it. ( i tried to exclude /include several time and same result.) version powernode greenwave "4.21"
Somebody have the same issue ? or is it an issue which come from to my PowerNode
/emoticons/default_icon_cry.gif" alt=":cry:" /> ...
hi guys,
I was under the assumption no power metering worked at all other than from manual declaration or fibaros own modules!
Thk for your answer. So if i understood i need to put manually the consumption in to parameters of module ?
I am no dev buddy but due to the complete lack of a simple yes or no by a Fibaro member of staff then I base my answer upon my own personal experience and until they fix the power metering class for 3rd party devices on beta then yes manual declaration is your only answer!
Bugzilla posted and also thread but nobody answered anything... quite a large part of the software considering they have a WHOLE tab dedicated to it
A few versions back Andrew put a lot of effort in helping to support power reading for the greenwave. all energy measurements of the modules should be there! They actually still work in my HC2.
Have not tried to re-include. But if it does not work anymore, it is a bug that has been introduced in one of the last betas.
Well Greenwave might still work I do not own one... but I can assure you my 3rd party devices certainly do not and NEVER have under the alpha/beta wave of updates! But did under 3.x
Actually it doesn't work. I had a Düwi switch in for service and it showed 0.70W when switched off and 0.40W when switched on for that socket. Unfortunately that was completely wrong as it still shows 0.40W when there is nothing plugged in. I checked it now and it doesn't report usage on any socket. So Powernode 6 doesn't seem to be fixed.
Horstmann / Secure SRT321 issues:
Looks like the combination of the heating panel and the Horstmann / Secure SRT321 (the room thermostat if you like) does not want to play together nicely.
The heating panel sets the temperature according to the configuration in the heating panel - but when I overrule the pre-configured temperature locally on the room thermostat it simply get's overruled again by the heating panel at the next wake-up.
This did NOT happen in 3.590, so I assume this is a new bug. Or did I miss something?
It is a bug since a while in the betas. But it has not been fixed yet. There for the heating panel quite useless... As overriding is something that should just work
Apparently, someone on a french forum have a Greenwave with a 4.20 firmware version, works fine on HC2 4.022 beta. ( issue come maybe of firmware version )
Guest David R
timed based scene's do not auto restart after fibaro alarm has been activated and reset. Need to log in and manually restart. Known bug?
I was not able to add my Schlage Link LE162. I followed the following steps:
1) Put HC2 into learn mode
2) Entered 6 digit programming code onto lock
3) Pressed # then 0
4) it didn't join .. got flashing red LED after a while
To properly add a secure device please repeat this procedure but please remember about two things:
1. To add a device in secure mode checkbox "Device is located far from the Home Center" must be unchecked (under Add button)
2. Device must me in close range to the controller (2m or less)
When you do it like this should work without a problem.
Thanks. I got it to connect
BUG: Schlage LE162 - Command to UNLOCK works. Command to LOCK does not.
I cant get the HC2 to go into recovery mode. I've followed the instructions, but the box is unresponsive, with all the LEDs on the front lit.
If I then reboot it again, it will boot up normally. Any suggestions?
Same here
Turn back in 4.022 in order to check DSA22 on my system.
I can confirm that :
- Automatic conversion from 3.590 fail (after the conversion DSA stop working)
- Delete device and Add it again let device to work
Thank you very much for help
Bye
Crippa Andrea
[ Added: 2014-12-13, 21:20 ]
found a conversion bug :
When converting from 3.590 to 4.X , the 2nd relay of the FGS221 device will be put into the room of the 1st relay.
Example :
Before conversion :
1 relay on room A
2 relay on room B
After Conversion :
1 relay on room A
2 relay on room A
See bugzilla ID
Guest fat
Could not add Lockwood Lock correctly. Added within 1.5m and unticked box for device is far from HC. Both locks added as 2 devices each for some reason and did not function
RGBW would not work from iPhone app and reported vastly different power usage from v3.x so I am not sure which one is correct
I can second the double relay issue that is mentioned above, when I upgraded I had one relay in media room and one unassigned and they both went into media room after upgrade
Recovered back to v3.590 and I added all devices from scratch as I could not control the RBG LED stripping that is across the front of my house
Updated to 4.022 here too.
Two main concerns:
-Since 4.019 I'm not able to see any backups . The list is empty, so I'm not able to restore any old backup.
-I'm still suffering a problem with door/window sensors of Everspring mini. No way to include them into the system, and they were working without any problem until 4.x was released.
I've also report it to the bugs page, but I could´t solve it yet.
fat, Did you give it heaps of time to finish it's thing when installing ? I unticked mine, added on the keypad ( 7 & 3 ?) then waited waited waited .. and when HC2 finished adding it still took a few minutes .. end result, each one probably took 10 minutes to add, and they are all working fine under 4.022. Except all you can do is open and close them still cant assign pins or log pins .. upside is that the battery reporting is working correctly now
Cheers,
al.
Guest fat
alandee, I added it and saw that it showed device 135 (Fibaro box) and device 135.0 (Door Lock). Left it quite a while and it didn't work for either of them. I will try again with another Beta. Thanks for the help
just got my aeon smart switch (Sorry fibaro please add power metering to ur switch)
switch is working as expected on off but the power metering isnt working option 80 is set to 2 and 90 and 91 are set. is this all that is needed and now its down to a beta bug????
thanks
Dave
