    Any delays in reading up the commands comparing to the TTS scenes to Sonos from HC2?
    I dint experience any delay and have to do text to speech conversion only once and save the file (although i used inbuilt voice notes). I think it does't do TTS convert every time we run the command.
    Does it have a TTS converter build in ?
    What languages are available, i need Dutch.
    You can find complete details from this link...http://www.z-wave.in/download/iPlay_Setup.pdf.6909e01e52991d40e9b413d56e4aec9c
    For more details email to [email protected]
    Guest Lode
    So as far as i can see in the manual iplay has not a build in TTS converter to other languages.
    There is some nice TTS software wich can record your audio but it's expensive.
    So i found this to do it for free in a lot of languages (including Dutch)
    Download Audacity
    Audacity is free, open source, cross-platform software for recording and editing sounds.
    Then browse to
    Select your language and voice and type in your message.
    While you listen to your text let Audacity record it, it records everything that passes your soundcard. With that in mind i disabled my microphone to eliminate background noises.
    Enjoy !!!!
    Download Audacity
    Then browse to
    Enjoy !!!!
    Great! That was a great tip Lode
    Actually, that deoends on your sounbdcard and your drivers. Not all are capable of recording loopback audio like this.
    Guest Lode
    Download Audacity
    Then browse to
    Enjoy !!!!
    So i deserve a discount ?
    [ Added: 2015-01-12, 17:15 ]
    Did you try it ?
    I have a problem with voice play. First I could not find the vfib's that were described. But thats not a big problem. What I do not understand is where I have to save the playlists.
    I can add an mp3 file to a playlist but it is gone after playing it. can somebody help me.
    thx
    thx
    Hi, You just have to click on the trash icon on the Playback screen to deactivate the "consume" mode that will remove the songs from your playlist after they are Played... email to [email protected]. Our team will assist you.
    after some minor problems finaly I understood the system.
    Now its running very well. Really very quick response and good sound quality. I was using cube-mp3 and a solution with android phone before but both were not reliable. IPlay is working much better. Good Job.
    All my sound files were recorded with IVONA TTS.
