Update HC2 4.023 BETA
Fibaro Home Center 2 v 4.023 BETA.
Beta version is designed for user testing and soon will be released as official.
WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
4.023:
New Features
Soft Reconfiguration option allows you to save settings, parameters and device ID. Thanks to that scenes with reconfigurable device will not require editing. Full reconfiguration will remove and add the device to the Z-Wave network, resulting in the loss of its settings, parameters and change the device ID.
Resolved Issues
#0001986: Not able to change params
#0002126: New Switch reconfigure Problem
#0002189: Danfoss LC13 E5 error after few days.
Fixed problem with some Z-Wave locks battery reports
Fixed problem with controlling blind lamels via web interface
Communication with Satel devices improved (response time reduced)
Known issues
Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Plugin for Sony TV will not work with newest Sony Firmware
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
4.022:
New Features
Remote access is available for this version.
Resolved Issues
#0001513 RGBW custom created programs
#0001640 sceneActivation trigger doesn't seem to work
#0001681 Add / remove device continuous loop
#0001772 the remote control (KFOB2) we as a dimmer in Fibaro HomeCenter2 indicated
#0001898 Greenwave 6-socket plug shows as 7 switches
#0001924 beta 18 can not save scene with lux as a trigger (fibaro pir)
#0001931 HRT4 ASR UNIT not work in the Version 4.xxx
#0002000 Danfoss LC13
#0002032 Danfoss LC13 marked dead moments after status shows as "device is awake"
#0002081 FGRGBWM-441: Cannot turn on/off using mobile applications
Fixes for Z-Wave locks (Yale, FollowGood, Schlage)
Fixes for Z-Wave thermostats
Fixes for 3.x -> 4.x conversion process
Issue with backup compatibility
4.021:
Resolved Issues:
#0001844 HRT4-ZW and ASR-ZW not working, causing the heating system to burn continously
#0002026 SSR-303 not properly recognize
#0001958 After recovering backup all devices where online. Now all battery devices has become dead
#0002095 After upgrade V3 to 4.019 random dead nodes appear
#0002087 Nodes marked as dead, but functioning.
#0002036 Wrong spelling in Delete Device window: "Learing" instead of "Learning"
#0002139 4.020 Horstmann hrt4 can not set association
incorrect values returned by fibaro:getValue (LUA)
Horstmann Thermostat HRT4-ZW does not save the association
Many other minor fixes
4.020:
New Features:
Pre-Update Confirmation - installing update on 4.020 or newer will prompt user additional confirmation.
Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network
Fixed Issues:
Incidental marking devices as dead
Horstmann Devices support
Many other Z-Wave engine fixes
4.019:
New Functionalities:
- Configuration > Backup now is Backup & Recovery
- Recovery Memory Status - can be checked on Backup & Recovery
- Backups - information about compatibility with current HC version
Resolved Issues:
#0001359: For some reason 1 smoke sensor doesnt show black box info.
#0001524: 3.902 Alpha - HUE plugin won't create new user
#0002037: Cannot delete device, but after a restart the devices shows as being deleted
#0002048: JSON ENCODE / DECODE doesn't work properly
#0001920: [ERROR] 09:23:47: line 44: attempt to index global 'json' (a nil value)
#0001699: panel energii
#0001849: Fibaro Door and Window Sensors do not report
#0001852: Unable to delete devices
#0001861: Since upgrading no scenes work
#0001877: HC2 stops working on 4.017
#0001709: When adding Foscam generic camera to plugin the password field is misspelled "Passwrod" should be "Password"
#0001824: Aeon Switch with energy meter. No more energy measurement/logging after upgrade to 4.017 beta.
#0001935: Notification of the battery status
#0001963: Event panel refreshed while browsing
#0001869: Fast scrolling in event history
#0001894: Log messages do not span columns
#0001655: Changing pages results in spinning wheel
#0001815: Power calcutaion is only working in rooms with Fibaro Wall plugs
#0001790: Virtual Device icon change causes a crash
#0001834: Get error 502 and 503 after virtual device import
#0001701: Controlled device is set to Air Conditioner on dimmers
#0001962: UI crashed after creation of magic scene
#0001966: setting " How frequently GPS position from the user?s iPhone should be collected" is not saved after reboot hc2
#0001888: Execution of lua commands
#0001907: Danalock POL_ZES100 (Z-Wave Danalock Square) sowing but not functional
#0001596: universal sensor has not the normal picture and dallas 18b20 temp does not work
#0001652: uni bin sensor breach scene does not work
#0001548: Nie działa triger włączenia włącznika Duwi
#0001812: HC2 doesn't respond anymore
#0001593: Email address validation wont allow + to be used
#0001651: HTML special characters being displayed in Virtual Device code
#0001946: fibaro:getSelfId does not work
#0001889: Unable to debug slider code
#0001992: FGK-101 with a DS18B2
#0002005: After creation of a magic scene i'm unable to login to the fibaro home center (keeps loading)
#0002023: Disarm sensors with scene
4.018:
Resolved Issues:
#0001566 All versions of FIBARO cannot support the switch state to return to the "Multilevel Switch Command Class, version 2"
#0001576 Untranslated text in Satel input/zone page
#0001578 Cannot change label value
#0001618 HSP02 no longer has parameters
#0001624 no different color for slave devices
#0001630 Reconfiguration did not run on a dimmer, resulting in no "sceneactivation"
#0001631 Roller Shutter 2 scene won't close
#0001711 Danfoss LC13 and older model are dead or E5 on the Danfoss itself
#0001773 Danfoss LC13 no Icon displayed
#0001747 Weather display wrong place
#0001834 Get error 502 and 503 after virtual device import
#0001836 Lili
#0001853 After upgrade web interface is slow when changing views
#0001873 No push messages possible on iPad/iPhone with 4.017
#0001880 Not able to set Variable manually anymore
many other fixes
4.017:
New functionalities:
User's Plugin Installation - ability to build and install Home Center plugin
FGHC Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Added support for American English (EN-US)
Plugins:
Nest - plugin for well-known thermostat
Netatmo - plugin for thermostat and weather station from netatmo
3.907:
This version mainly concentrate on adding better support and integration for more devices (not only z-wave device).
Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.
New Home Center software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards like TCP/IP, IR*, RS 232*, UPNP. Plugins have their own user interface and can call all APIs available on HC2. Possibility of building plugins by independent developers will be introduced in next versions.
* required additional hardware.
New functionalities
Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
Magic Scenes - new, simplified and easy to use graphical way to create scenes based on condition > action flow.
Temperature Panel - allows to see history of temperature changes in rooms and on each device.
Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
Z-Wave Door Locks support - controlling and PIN settings.
Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts at iPad and Web Page. Sensitivity level is now easier to set.
Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
Device hiding - device that is not in use can be hide without removing it.
Device deactivation - deactivated device is visible in UI but can't be controlled.
Multithreading added for HC (server and z-wave) - now engines work much faster.
Event panel moved - for better usability now is available in menu on right side of screen.
User rights management - moved to Configuration.
Block Scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
Lua Scenes - updated tooltips for devices.
Plugins:
Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
Plugins search
Network devices search via ARP
Plugins category Safety:
DSC Alarm - for DSC Alarms,
Helios Basic - integration using Basic license,
Helios Gold - integration using Gold license
Mobotix - for Mobotix videophone,
Satel Alarm - for SATEL
Plugins category Cameras
more than 100 devices from various manufacturers
Plugin category Climate
Carrier Furance
WS Davis Vantage
Plugins category Multimedia
LG Bluray
LG TV
NC + mediabox
XBMC Remote Control
Denon Amplifier
LG Bluray
Onkyo Amplifier
Philips Bluray
Pioneer Amplifier
Samsung TV
Sonos
Sony Bluray
Sony TV
Plugins category Other
Philips Hue
Wake on LAN
Other changes
Many other improvements to the system
Users who use version alpha from 3.901 to 3.906 need to perform recovery first and update from 3.590 after restoring backup.
  • Answers 116
  • Created
  • Last Reply
nice work.
Upgrade done..will test the Danfoss
Nice options Zwave soft reconfigure. and the diatonic screen..
dsilletti , can we look at your system (UBS 1.2 issue)?
The new zwave diagnostic screen is great.
I have some none Fibaro modules..all will display in this screen..
Please add some default templates for none Fibaro modules.
For dimmers en switches.. this will make the list shorter.
Guest MikeGooder
Hm, myiPad just sits on "loading data" with 4.023 Have killed/restarted app and rebooted iPad without any change.
Just me?
seen this on the iphone, if the account did not have access to certain devices and scenes it would hang loading data. I just gave access to all devices and scenes and it hasn't happened since
Maybe the same ?
Cheers
Mike
system crash in 2 hours..
503 error
Same here - 503 error. That's the first time I get any kind of error. I was checking the consumption panel and selected a sensor in the power consumption panel when it instantly went to 503. The power and temperature readings were all blank so I thought I'd check. Probably shouldn't have
The thing that sent me there was the NaNW reading on the top header stats:
TANE, UrSv please pm me if you are able to give us access to your systems.
We would like to check what is the problem.
I'm also having a 503 error.
What do you need to fix this...
You would probably get help sooner if you contacted Support rather than reporting in Bugzilla.
Support is not for Beta's, it is for stable only
pm send
PM sent.
Guest dsilletti
Hi, can you please access my system now?
I can provide TeamViewer data.
thanks
Domenico
    thanks
    Domenico
    dsilletti,
    Please PM me.
    Guest dsilletti
    thanks
    Domenico
    dsilletti,
    Please PM me.
    You've got mail
    Domenico
    How are you going to fix bugs and make stable if this is your answer?
    Dear Sir,
    You need to perform a recovery and return to stable version
    as we are not able to provide full support for BETA versions.
    1) Turn off the device by disconecting power supply
    2) When turned off, turn it on again with recovery button “+” pressed (next to power)
    3) When LED are flashing from left to right, please release recovery button “+”
    Then it should be visible in LAN network. There you choose recovery option.
    Your password and login will be reset to admin,admin after that.
    Kind regards
    [ Added: 2014-12-16, 16:50 ]
    Look how many 503 errors lol hahahahahaha and I thought I was mad! I was told they don't know why
    /emoticons/default_icon_smile.gif" alt=":-)" /> reassuring eh!
    Danfoss LC13 are fine with this update.
    The Batpowered Sirens from Vision Security are showing as not configured, also new Softconfig does not help.
    The Bat Icon showing always empty, although they have new batteries.
    Pls check.
    Guest dsilletti
    thanks
    Domenico
    dsilletti,
    Please PM me.
    Thank you for quick and resolutive support,
    My UBSs have got motion sensors back!
    Well done Fibaro Team!
    waiting for new fixed release...
    Regards
    Domenico
    [ Added: 2014-12-16, 18:07 ]
    remaining issue:
    even after hard reconfiguration of my UBSs (soft reconfiguration was not available), the button soft reconfiguration is not available for Main_Zwave_Device (UBS Master), is available only for child sensors.
    Regards
    Domenico
    [ Added: 2014-12-16, 18:16 ]
    P.S. Anyway iPhone app shows no device of this type for motion sensors and for temperature sensors
    503 error
    same here
    503 error
    same here
    do you know it's any possibility to restart HC2 with 503. I was try by IP/api/settings/rebot
    but i got only
    HELP!! i cannot do it manualy...
