Mad-Cat 1
i posted in the 4.030 but think wrong place with the avalanche of well..
Just thought id share my parameters for the aeon labs smart switch
the pic has the ones im using now and IT WORKS FINALLY thank u fibaro finally have power metering back
below is an out take of the manual with all the parameters be nice if fibaro included this in the build as a template
if anyone know how to get the watts and the kw hour would be great if possible and also have the descriptions in the thing would be nice too.... if anyone has a better one please share too
Configuration Parameters
Type of Sensor Report (Parameter Number 1, Parameter Size 1) Defines the value type to be sent as
Sensor Report.
Value Description
0 Power (Default)
1 Voltage
Blinking Behavior (Parameter Number 2, Parameter Size 2) This is a double byte value. The LSB defines the total time the device need to blink. The value if set in seconds. The MSB defines the on/off interval of the
blinking. The unit is 0.1 s.
Value Description
0 — 65535 Configuration Bytes (Default 0)
Notification on Status Change (Parameter Number 80, Parameter Size 1) Defines the automated status notification of an associated device when status changes
Value Description
0 Deactivated (Default)
1 Hail sent
2 BASIC Report Sent
Disables Function of automated sending of a Report triggered by minimal change of value.
(Parameter Number 90, Parameter Size 1)
Value Description
0 Disabled (Default)
1 Enabled
Minimum Change to send Report (Watt) (Parameter Number 91, Parameter Size 2) The value represents
the minimum change in Wattage for a Report to be sent .
Value Description
0 — 32000 W (Default 50)
Minimum Change to send Report (%) (Parameter Number 92, Parameter Size 1) The value represents the minimum change in Watage Percent for a report to be sent
Value Description
0 — 255 % (Default 10)
Report type send in Reporting Group 1 (Parameter Number 101, Parameter Size 4) Defines the type of report sent for the Reporting Group 1.
Value Description
2 MultiSensor Report
4 Meter Report for Watt
8 Meter Report for kWh (Default)
Report Type send in Reporting Group 2 (Parameter Number 102, Parameter Size 4) Defines the type of report sent for the Reporting Group 2.
Value Description
Report Type send in Reporting Group 3 (Parameter Number 103, Parameter Size 4) Defines the type of report sent for the Reporting Group 3.
Value Description
Send Interval for Reporting Group 1 (Parameter Number 111, Parameter Size 4) Defines the time interval
when the defined report of Reporting Group 1 is sent out.
Value Description
0 — 65535 Interval (Default 720)
Edit
1 or two meters working
7 answers to this question
