Working push notifications?
Since iOS 8 push notifications in the Fibaro app are broken. I already pointed to a possible solution. Since Fibaro is not capable of fixing, what alternatives do you use?
This is an essential part of a security system.
Any way to do this in Lua?
This doesn't work.
I want to send information about which sensor is breached. Therefore I need Lua.
Did you try with FHttps?
I tried with something like this form a pre. post by Sascha but can't get it to work.
- Can we use HTTPS client?
This doesn't work.
See this, it works in LUA:
dawiinci,
try:
1 - Try to remove the iOS application from your smartphone
2 - Remove the iOS device in "configuration panel", section "users"
3 - Install last iOS application and configure with your "home Fibaro" credentials for the first lunch.
it worked for me and for other people
Did this soloution on 2 android phone's and everything is ok now.
instead of iOS, delete app on android, delete device in HC2.
install again and configure your HC in the app.
works like a charm
hello I tried with the proposed solution dawiinci, but it does not work on that on ipad and iphone , iphone of my wife it works.
all devices are updated to ios 8
thanks Amos
