For those that did not know .net was in scenes
.net in scenes if you had not worked it out. Has been there since alpha.
Change for your password this is admin:admin
  • Answers 48
  • Created
  • Last Reply
arg still can't get it to work :/
3 hard reboots and its back to normal!
[ Added: 2015-01-18, 20:14 ]
sj3fk3
you have added the header yes?
[ Added: 2015-01-18, 20:15 ]
Content-Type: application/x-www-form-urlencoded
not sure if its a requirement but looks like it should be included?
[ Added: 2015-01-18, 20:16 ]
headers = {
["Content-Type"] = "application/x-www-form-urlencoded"
    to head off the next question
    wt-heck is that some decoding or encoding?
    You need to encode your user password into the header
    headers = {
    ['Authorization'] = 'Basic YWRtaW46YWRtaW4='
    only works for admin admin
    this is for pushover no password required i though? just token,user,message according to api
    Function for POST method, proper data must be passed as argument:
    Thanks! But I'm clueless how to incorporate this with the payload I need to send :/
    not tested but something like
    not tested as I am away from home so can not test
    That .net was in scenes
    Do you know where I can find the documentation? If searched my @$$ off and can't find it.
    [ Added: 2015-01-19, 13:52 ]
    Does not do anything :/ Not even an error..
    Go on Dean you have a machine to test on. A few lines to fix
    i tried but i do not understand why the admin:admin code was required that you put after? do we need to authenticate with the homecenter to even allow any put requests?
    headers = {
    No basic auth for pushover It is useless
    /emoticons/default_icon_wink.gif" alt=";-)" /> Pushover only need
    Maybe you do not know: No basic Auth to request fibaro API, example:
    Nice did not know they had that port on loopback.
    Can anyone point me to the documentation of this .net module? Or even the source? I would really like to get
    to work with fibaro.
    There is some on developer.fibaro.com but does not cover loopback
    It also does not cover https but as far as I know that is because that is still on wish list
    This works! Finally I can send pushover mgs via lua! \o/
    %% properties
    %% globals
    local selfhttp = net.HTTPClient({timeout=2000})
    local msg = "anything you want"
    local requestBody='token=entertoken&user=enteruser&message=' ..msg
    selfhttp:request('https://api.pushover.net/1/messages.json', {
    options={
    headers = selfhttp.controlHeaders,
    data = requestBody,
    method = 'POST',
    timeout = 5000
    success = function(status)
    local result = json.decode(status.data);
    print("status");
    if result.status then
    print("successful");
    print("Request: " ..result.request);
    else
    print ("failed")
    end,
    error = function(error)
    print "ERROR"
    print(error)
    sj3fk3, Can you please advise. I tried the code in a VD but gets
    "[ERROR] 10:25:52: line 6: attempt to index global 'net' (a nil value)"
    I have removed all blanks.
    KristianO, you must have HC in version 4.x
    A.Socha,
    I have HC2 in 4.031
