For those that did not know .net was in scenes
.net in scenes if you had not worked it out. Has been there since alpha.
Change for your password this is admin:admin
  • Answers 48
  • Created
  • Last Reply
you using that in scene right?
A.Socha,
No, why can't i use it in a VD? It would make more sense to have multiple buttons with different texts.
When is push fixed by Fibaro?
A.Socha,
For VD buttons use this:
IP address: 108.59.13.232
Port: 80
Example Alarm message with confrmation send to all registered devices on Pushover:
Normal message send to a certain device:
Replace and with the API codes you get from the pushover websites, after registering and adding the appilcation. Register every device by installing the app and naming the device in the mobile app.
sj3fk3, Can you please advise. I tried the code in a VD but gets
"[ERROR] 10:25:52: line 6: attempt to index global 'net' (a nil value)"
I have removed all blanks.
It was already possible to do in a VD (see else where in the forum), this is code for a lua scene..
sj3fk3,
Thanks! My wish was to be able to use it in a LUA VD too. Since i don't really "like" pointing to an IP adress that might change, i rather prefer the domain.
sj3fk3,
If you ask me, using a lua scene is much better, that way you can make a general pushmsg script that pushes any desired variable/string.
Port: 80
Should this still be working?
I cannot make it work with my key and token for some reason. Also tried 162.216.6.175.
This works! Finally I can send pushover mgs via lua! \o/
%% properties
%% globals
local selfhttp = net.HTTPClient({timeout=2000})
local msg = "anything you want"
local requestBody='token=entertoken&user=enteruser&message=' ..msg
selfhttp:request('
options={
headers = selfhttp.controlHeaders,
data = requestBody,
method = 'POST',
timeout = 5000
success = function(status)
local result = json.decode(status.data);
print("status");
if result.status then
print("successful");
print("Request: " ..result.request);
else
print ("failed")
end,
error = function(error)
print "ERROR"
print(error)
... And could not get that to work either.
Got this:
[DEBUG] 16:01:34: status
[DEBUG] 16:01:34: successful
[DEBUG] 16:01:34: Request: 084a8d9389e8965c4976a3c501eb61fa
... but no push to my registered iPhone.
Has anything concerning push or pushover changed recently that stops the code in this thread from working?
