Sunset scene - 1hour after the actual sunset
I have an HCL running version 3.593.
I have a simple scene that should run @ sunset (turn ON outside lights), but it is happening, every day, exactly one our after the real sunset.
I filled all the location settings (check image attched) and all seems to be right except for the sunset hour.
Can some one help me?
Is there any setting that i'm missing?
5 answers to this question
Hi luisgonc,
can you post a screenshot of your scene?
Cheers
Alfons
    Hello awliser,
    It seems a very basic scene, but I may be missing some detail.
    But because it is happening 1 hour after the sunset, every day, I thing it may be related with the sunset calculations for this particular location.
    What do you think?
    Hello awliser,
    What do you think?
    Hi Luis,
    the scene seems ok. I have no problems at my location with sunset/sunrise times. Have you doubl-checked the coordinates you defined and the system time? If both ok, I suggest opening a ticket with Fibaro support.
    Cheers
    Alfons
    Try and use " pt.pool.ntp.org"  instead of "pool.ntp.org", don't know if it helps, but there was a reason why I had to use "nl.pool.ntp.org"...
    Hello Remko,
    Thankyou for the tip.
    I will change the NTP server to see if it changes anything.
    Cheers,
    Luis
