RiccardoCanetta 13
Hi
Today I found my HC2 stuck at boot with all leds on: both in rescue mode and normal boot would end up with all leds on and no possibility to reach gateway, not even with rescue ip address.
I realised that the temperature in the room (in a house where we don't normally live) was too low, around 5 degrees. I heated the HC2 in front of a wood stove and then it magically started up normally!!
So I now programmed HC2 to keep minimum 10 degrees in its room, as per its technical specs
Hope it helps someone else stuck with all leds on..
Riccardo
