HCL, how to trig scenes with FGD211 Dimmer?
Hello, according to FGD211 Dimmer instruction manual it seems that is possible to control scene with S1 Dimmer switch, is this possible with HCL too? Nothing is mentioned in FGD211 instruction manual, it says just that is possible...
If someone can help me on this showing some block diagrams example thanks!
6 answers to this question
I think not; if I remember correctly SceneActivation requires LUA. HCL does not have LUA
    Ah, but is seems very strange, I guess that even a "basic" controller like HCL has to do that!
    /emoticons/default_icon_confused.gif" alt=":-?" />
    Its possible! Create a scene and add the dimmer as trigger. Choose "Scene activation" and id (According to manual) to be the trigger.
    Please also check that the dimmer parameter for sceneactivation is active.
    Hi Kristian!
    Thanks! Can you help me little more explaining better "Choose "Scene activation" and id (According to manual) to be the trigger."
    Can you post a picture this might help me a lot as I'm a newbie!
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    Sorry, but this is only possible in version 4.x and HCL is not there yet.
    But when, it will be possible to select as a trigger option in the scene blocks like "Open, Close..."
    Ah Okay... I really hope that this feature will come soon on HCL too! It's too much important even for a "basic" equipment!
