Hi
what am i doing wrong in this scene i am trying to:
if the outside temp is below 3 then set danfoss to 28 for one hour and then danfoss to 4 in one hour
i did make to scene for this:
%% properties
164 targetLevel
3 Temperature
%% globals
setTimeout(function()
local delayedCheck0 = false;
local tempDeviceState0, deviceLastModification0 = fibaro:get(164, "value");
if (( tonumber(fibaro:getValue(164, "targetLevel")) == 4 ) and (os.time() - deviceLastModification0) >= 3600) then
delayedCheck0 = true;
if (
 ( tonumber(fibaro:getValue(3, "Temperature")) < tonumber(3) )
and
 ( delayedCheck0 == true )
or
then
      fibaro:call(164, "setTargetLevel", "28");
end, 3600000)
and
%% properties
164 targetLevel
%% globals
if (( tonumber(fibaro:getValue(164, "targetLevel")) == 28 ) and (os.time() - deviceLastModification0) >= 3600) then
if (
or
then
      fibaro:call(164, "setTargetLevel", "4");
end, 3600000)
regards
Elvar Páll
www.webcam-iceland.com
Something like this:
    Tanks i like this script but it i does only run ones so i added autostart and change fibaro:sleep to 4 sec for testing and added
    fibre:sleep(2) at the bottom .
    what am i missing it only run ones ?
    %% autostart
    %% properties
    3 Temperature
    %% globals
    local debug = true;
    -- check script instance count in memory
    if (tonumber(fibaro:countScenes()) > 1) then
      if debug then fibaro:debug("Script already running."); end
      fibaro:abort();
    if ((tonumber(fibaro:getValue(3, "Temperature")) < 3) or (startSource["type"] == "other"))
    then
      if debug then fibaro:debug("Outside temperature below 3, setting target level to 28"); end
      fibaro:sleep(4000);
      if debug then fibaro:debug("Waited one hour, setting target level to 4"); end
      fibaro:sleep(2000);
      if debug then fibaro:debug("Waited 1 hour, start again"); end
    The way I did it was that the trigger is the change of temperature. So if temperature of device ID 3 is changing it is running the script, looking if the temperature is below 3 and then set the settargetlevel. If during this hour the temperature will rise it will run again, but will be aborted due to the first part of the script (only allowd to run 1 in a time).
    So to test it, you should make sure the temperature is changing for device ID 3.
