hansdr 0
Hi all,
I have problems with the script below.
Can anyone say what is going wrong?
I have debug message added at the bottom.
Thanks You.
Thanks to MSB for the script
%% autostart
%% properties
%% globals
ActivityProjector
ActivityTV
LastSeenHans
LastSeenChrista
TV
Projector
Home
Night
--kill any extra instances of the same scene
if (fibaro:countScenes() > 1) then fibaro:abort() end;
--Loop
while true do
--Settings
local ExecuteTimer = 60; -- Execute Every N-th second
local GlobalVariablesDevice = 174; -- ID of helperdevice for GlobalVars!
local AbsenceTime = 10; -- 10 minutes
local SunriseTime = 30; -- 30 minutes after sunrise
local SunsetTime = 30; -- 30 minutes before sunrise
local UserInactivity = 10; -- 10 minutes delay after switchoff
--Setup local variables
local CurrentDate = os.date("*t");
--Announce start
fibaro:debug(" -|- Start: "..os.date("%Y-%m-%d %H:%M:%S",os.time()))
-- LastSeenHans,Christa
fibaro:call(GlobalVariablesDevice, "pressButton", "11"); -- Check if Hans is at Home
fibaro:call(GlobalVariablesDevice, "pressButton", "12"); -- Check if Christa is at Home
local LastSeenHenrik = fibaro:getGlobalValue("LastSeenHans");
local LastSeenJennie = fibaro:getGlobalValue("LastSeenChrista");
fibaro:debug(" -|- LastSeenHans: "..os.date("%Y-%m-%d %H:%M:%S",LastSeenHans));
fibaro:debug(" -|- LastSeenChrista: "..os.date("%Y-%m-%d %H:%M:%S",LastSeenChrista));
-- Home, anyone ?
AbsenceTime = os.time() - (AbsenceTime * 60);
fibaro:debug(" -|- AbsenceTime: "..os.date("%Y-%m-%d %H:%M:%S",AbsenceTime));
if tonumber(LastSeenHans) < AbsenceTime and tonumber(LastSeenChrista) < AbsenceTime then
fibaro:debug(" -|- Home: Noone is Home!");
if tonumber(fibaro:getGlobalValue("Home")) == 1 then fibaro:setGlobal("Home", 0);
else
fibaro:debug(" -|- Home: Someone is at home!");
if tonumber(fibaro:getGlobalValue("Home")) == 0 then
fibaro:setGlobal("Home", 1);
-- SunriseTime
SunriseHour = os.time{year=CurrentDate.year, month=CurrentDate.month, day=CurrentDate.day, hour=string.sub(fibaro:getValue(1, 'sunriseHour'), 1 , 2), min=string.sub(fibaro:getValue(1, 'sunriseHour'), 4)}+SunriseTime*60;
fibaro:debug(" -|- SunriseTime: "..os.date("%Y-%m-%d %H:%M:%S",SunriseHour));
-- SunsetTime
SunsetHour = os.time{year=CurrentDate.year, month=CurrentDate.month, day=CurrentDate.day, hour=string.sub(fibaro:getValue(1, 'sunsetHour'), 1 , 2), min=string.sub(fibaro:getValue(1, 'sunsetHour'), 4)}-SunsetTime*60;
fibaro:debug(" -|- SunsetTime: "..os.date("%Y-%m-%d %H:%M:%S",SunsetHour));
-- Night or day?
if (os.time() > SunsetHour or os.time() < SunriseHour) then
fibaro:debug(" -|- Night: It's night!");
if tonumber(fibaro:getGlobalValue("Night")) == 0 then
fibaro:setGlobal("Night", 1);
else
fibaro:debug(" -|- Night: It's day!");
if tonumber(fibaro:getGlobalValue("Night")) == 1 then
fibaro:setGlobal("Night", 0);
-- TV running?
if tonumber(fibaro:getValue(19, "valueSensor")) > 10 then
fibaro:debug("-|- TV: TV is ON");
fibaro:setGlobal("ActivityTV", os.time());
if tonumber(fibaro:getGlobalValue("TV")) == 0 then
fibaro:setGlobal("TV", 1);
elseif (os.time()-(60*UserInactivity)) > tonumber(fibaro:getGlobalValue("ActivityTV")) then
fibaro:debug("-|- TV: TV is OFF");
if tonumber(fibaro:getGlobalValue("TV")) == 1 then
fibaro:setGlobal("TV", 0);
else
fibaro:debug("-|- TV: TV is Undetermined");
-- Projector running?
fibaro:debug("-|- Projector: Projector is ON");
fibaro:setGlobal("ActivityProjector", os.time());
if tonumber(fibaro:getGlobalValue("Projector")) == 0 then
fibaro:setGlobal("Projector", 1);
elseif (os.time()-(60*UserInactivity)) > tonumber(fibaro:getGlobalValue("ActivityProjector")) then
fibaro:debug("-|- Projector: Projector is OFF");
if tonumber(fibaro:getGlobalValue("Projector")) == 1 then
fibaro:setGlobal("Projector", 0);
else
fibaro:debug("-|- Projector: Projector is Undetermined");
--Announce end
fibaro:debug(" -|- End: "..os.date("%Y-%m-%d %H:%M:%S",os.time()))
--Sleep XX seconds
fibaro:sleep(ExecuteTimer*1000);
[DEBUG] 18:20:41: -|- Start: 2015-03-21 18:20:41
[DEBUG] 18:20:41: -|- LastSeenHans: 2015-03-21 18:20:41
[DEBUG] 18:20:41: -|- LastSeenChrista: 2015-03-21 18:20:41
[DEBUG] 18:20:41: -|- AbsenceTime: 2015-03-21 18:10:41
[ERROR] 18:20:41: line 46: attempt to compare nil with number
