Stealth 10
I'm looking to upgrade my garden irrigation system and integrate it into my HC2.
My current system uses 24v DC powered solenoid valves which are triggered via opto-coupled relays with a coil voltage between 5-15v DC.
I want to control up to eight zoned valves from the HC2 web interface through schedules and interface switches (simular to how a light would be switched on/off but showing irrigation icons)
Can I / should I use a Fibaro RGBW Controller?,
or can I use the Fibaro Universal Sensor? (I'm not sure I can switch the two outputs of the UBS from within the HC2 interface though?)
Thank you for any advice / recommendations in advance....
19 answers to this question
