But it implies to... If I read this in a manual, I won't be afraid it can be broke due to some water.
but that doesn't make it waterproof.....
cheers
emiel
Agreed! Thank you for pointing out that my post might confuse people. I have edited it to make it clear that it is not waterproof.
The 6-in-1 gives me 4 devices, 2 temperature, 1 lux and 1 humidity. Where as the first temp shows 255 or 0 deg. No template..
Yes, that's how it shows on 4.056. I can't get it any better than that (on Fibaro HC2).
Same here on .56. However my first reading of either 0 or 255 has a different icon.
  • 4 weeks later...
Missed this one for a clean sweep of Aeotec devices! Any chance for next release?
the first one that has 0 or 255 is the motion sensor......when motion is detected it goes to 255.......i get 4 icons, temp shows zero, lux shows zero, humidity and the motion one that isn't a motion icon..........any idea of when this will be included in the fibaro templates?
My sensor also shows the same, the motion becomes temp sensor that goes to 255 when motion is detected. however the lux, humidity and real temp actually work as intended after I changed the parameter as shown in the manual. I made it to report the change quicker.
