HC2 keeps crashing (503)
Guest fayelund
Singe update 4.037 my HC2 keeps getting the 503 Server unavailable error. Pushing reset services on the webpage works, but it crashes again quite fast.
Has anybody else experienced this issue?
I have tried to reset the z-wave network, but it did not help.
Have thought of resetting the device to factory settings, but I cannot find an option for that (It was an option on v3), does anyone know if it is possible to factory reset?
There should be a hard reset on the HC2 manual. Take a look and do hard reset.
I had the same problem
I called Fibaro support and they help me out with it ,
What was my Problem , I had some virtual Devices and some scenes which were not cleaned and polluted my whole HC2 , after some cleaning everything works like charm again.
So please check your Virtual Devices and scene , main loops .
Or call support , they are very friendly and good guys.
( PS I would recommend to install putty on your computer , so they can work faster )
Guest fayelund
    Deleting all virtual devices seemed to fix it. Thanx, fuuss.
