Hi all.
Having a bit of an issue with the Fibaro HC 2 and the Fibaro FGK 101 Windows Sensor.
The battery ran out in it so replaced the battery.
When i put the top cover back on after connecting it, for some reason it lost the association with my HC2 and would not get picked up at all. Thought i may have wiped it
So my plan was to remove it from the system and re add it
/emoticons/default_icon_idea.gif" alt=":idea:" />
I clicked on remote Z-Wave Device and this removed cleanly, I then tried to delete the device from the device list on the HC2 and it seemed to go. When i refreshed the page, the device came back. There is also a temperature sensor hooked up to it and this does the same; try and remove it, looks like it has been removed, refresh the page and it is still there.
/emoticons/default_icon_eek.gif" alt=":shock:" />
I have tried in IE, Chrome and on my Mac but still it will not remove
/emoticons/default_icon_exclaim.gif" alt=":!:" />
I have managed to re add the Door sensor and Temp sensor and these are working well. Just want to get rid of the 2 rouge devices.
Can anyone help me at all.
Thanks,
Hal
There is a bug in the latest fw. Will be fixed in the new relaise.
I have exact the same issue with this sensor.
Removing the sensor will not work. Adding a "new" sensor is possible, but the old one cannot be removed.
I hate it to say this, but all these bugs irritates me.
It is already fixed in next software, until then all you can do is hide these devices to keep them out of sight.
    No problems.
    Just a big annoyance with a permanent battery light showing on the top of the web gui.
    Thanks for the replies,
    Hal
