Problem with heating panel and Multireg/ Heatit termostat
Hi.
I can not geat the heating panel and schedule for my heatit thermostat ( Multireg z-wave from Thermo-Floor) to work properly. Also it show the wrong ikon i the gui. And it can not regulate longer up than to 28 degrees celcius. Is the thermostat not properly supportet ?
We have this device and it is on our to-do list when it comes to integrating devices. There are currently some issues with it.
There is a new updated firmware for these new thermostats..  I waiting for mine to arrive.
I also got the heatit thermostat. I also cant configure the device because of missing template.
But I also cant see the current temp in HC2, the temp displayed on the thermostat does not match the Sensor in HC2.
Is this a thermostat issue or HC2 issue?
Another problem is that despite that the max target value on the device is 35 degrees, HC2 only allow me to set up to 30 degrees. HC2 issue?
This is changed in the newest software. The temperature reported back to the gateway will be the same as the sensor you use.
On earlier software versions it always reported back the air sensor temperature even if you where using a floor sensor.
Thanks a lot! That make sense! I just got the same info from the Thermofloor.
What about the other issue?
I can't say for sure but that sounds like an issue with the HC2 not having a template.
I have the new thermostat with the new firmware on order so will know more how it works with the HC2 soon.  We will need a HC2 template though!
    I have the HCL an i can't set the temperature to more than 28 degrees.
    But it seems that thees issues is about to be solved, so then i do not have to worry that the other 5 that i have ordered from thermo-floor won't work properly
    i received two thermostats today , with new software  (z-wave plus)  .
    will try to get them included in hc2 tomorrow . will update here if any issues come up.
    I believe the old version was also z-wave plus?
    The way you can tell if the have cooling as well as the heat option.
    I'm still waiting for mine so I would be interested in your findings.
    Thanks Steve
    Now i have added the two thermostats to my hc2.
    They are working fine ,but  missing template.
    I hope fibaro will add template for the next software upgrade.
    Stealth - the first thermostat i bought was not with the cooling option ( only heat and comfort)
                  this i have at home now trying to include it to a shitty Vera Lite...
    Fibaro - let me know if you need any info from me regarding the themostat. ( if this is a different version than you already have)
    They are working fine ,but with missing template.
    Fibaro - let me know if you need any info from me regarding the themostat. ( if this is different version than you already have)
    Where you see heat and heating in the drop down boxes do you have an option for cooling?  I'm told this is how you know its the new firmware devices.
    Steve
    Steve
    Yes i have this option on the two new ones
    Great!  So they do exist.  I was beginning to think the suppliers were telling me fibs...
    Thanks.
    Hmmm received the heatit 2nd of May, but without the cooling option... I see that you have version 1.4, I have 1.2...
    Send them a mail and ask for them to update the software   -
    I am sure they will tell you to send it to them by post and they will update it for you .
    Edit :  Deleted this post ...
    Are you only seeing the cooling option on the Vera Lite and not yet in the Fibaro user interface?
    I now have my new thermostats but the cooling option and the floor sensor is not displaying its temperature in the Fibaro user interface also. I'm wondering if thsi is beacuse we still don't have a template.
    Steve
    How is it going with this multireg thermostat?
    Are there any solotion for the issues regarding heatingpanel and sheduling for HCL ??
    Any news on the Multireg Template?    It`s starting to get cold up here in the north.., and it would be great to select more than 28C in the app....
    Can we expect something in the 4.057 release ?
