Problem with heating panel and Multireg/ Heatit termostat
Hi.
I can not geat the heating panel and schedule for my heatit thermostat ( Multireg z-wave from Thermo-Floor) to work properly. Also it show the wrong ikon i the gui. And it can not regulate longer up than to 28 degrees celcius. Is the thermostat not properly supportet ?
Downloaded template (also sent by email)
04019B000100010603530104truefalse86com.fibaro.setPointThermostatSetpointMultilevelSensorThermostatModeAssociationPowerlevelConfigurationBasicZwaveRoutingSlavevalue0temperaturecom.fibaro.temperatureSensorC2147483647-21474836481supportedSensorTypes66601mode25502mode25502mode25502mode25502mode25502supportedModescom.fibaro.operatingMode2value2147483647-21474836480value2147483647-21474836480timestamp9223372036854775807-92233720368547758080targetLevel2147483647-21474836480mode25500supportedModescom.fibaro.setPoint0dynamicInfo0zwavePlusVersion25500roleType25500nodeType25500InstallerIconType9223372036854775807-92233720368547758080UserIconType9223372036854775807-92233720368547758080parameterszwaveConfiguration25500value0associationszwaveAssociation2550associationGroupszwaveAssociation9223372036854775807-92233720368547758080currentActiveGroup25500
I'll reignite this thread with a question that might have obvious answers, but hey, I'm new so bear with me
I just installed five Multireg thermostats and upon adding them I've noticed that each have three slaves.
Now, the two first seem fairly obvious but the third one has me a bit puzzled.
It has 4 options; 'Heat', 'Cool', 'Energy Save Heat' and 'Off'
Except for the 'Cool' option those are fairly self explanatory, but all these options save for 'Off' is also present on the first slave.
What happens if I set the first slave to 'Heating' and the last one to 'Cool'?
I'm also fascinated by how my underfloor heating now also can act as cooling devices
Can you help me? Temperature stays zero? But the .2 temperature works fine. What can i do?
Thnxs
Bart
@bcmeijer: I have the same problem. The first device shows 0.00 C.
Anyone know how this problem can be solved?
do you solve the problem?
I don't have the samed temperature between the sensor and the temperature wrte under the thermofloor
