elev8john 0
I am a newbie but eager to understand and learn the HC2 which I have found to be impressive after only a few days exploring.
I want to experimentally connect the RGBW to a 5mtr LED strip that arrived with its own 12V power supply and a 240 volt plug. I have found and understood how to add the module as a device into the HC2. No problem there. I can see that I will need to connect the RGBW wires into the corresponding colour connectors on the RGBW Fibaro module. I can see where I can get the 12v DC and where it needs to be connected same as the ground or negative. What I dont get is the IN1 - IN4?
All I want to do is simply see my Iphone APP control the strip, change colour, change intensity, turn on turn off.
So I am thinking short all 4 "IN" ports to ground?
Short only one "IN" port to ground?
Any help on this would be appreciated, thanks
Link to post
9 answers to this question
