Hey guys!
Is it possible add a priority in scenes?
I have a scene which switches the lights in the floor on when I come back and light condition is below the threshold value.
There are two triggers in the scene: motion sensor and door sensor.
Unfortunately the light is also switched on when I´, leaving.  But I dont need it when I leave.
How can I tell the scene that the door sensor needs to be triggered first and the motion sensor then before the scene gets started?
Alex
Use a variable called Home or Away, use the door sensor to set the variable and check if it is set before turning on the lights. How to reset the variable is something you may have to figure out. Maybe you just use one door and can toggle the variable or a timer of some sort or perhaps geofency or maybe fibaros own gps capabilities.
    Thanks for your suggestion, Joacim.
    In general it cannot be that hard to implement this function into the block scene creator.
    Maybe Fibaro will add it in future. I hope t least.
    Alex
