Today I Add a new door sensor FGK 101 in combination with een DSB1820 temp. sensor and a binary switch. All sensors work correct but on the advance tab there are no parameters.
The message below is shown.
Configuration
The device does not have a template by what might have limited functionality, please contact technical support in order to add the template for this device.
I had this problem my self a couple of times
what i have done to solve this was
remove the sensor from system
reset sensor
restart HC2
include again the sensor .... make sure you wait when you trriple click the button.....
after that wake up the device manualy
configuration finished
All done
Christos
    When I use Google Chrome the door sensor parameters are not visible.
    When I use Internet Explorer the door sensor parameters are visible  :->
    Did you try to clear cache memory of your Chrome browser?
