Towanda 0
Hello!
Last night i tried to upgrade my system to 4.048 but I guess something went wrong. L
After the upgrade instead of rebooting all leds where lit up and stayed that way. After about 20 mins I disconnected the power supply and reconnected it.
HC2 began to boot up normally but when all leds where lit up they stayed that way for a while, then all leds turned off and nothing else happened. This still occurs when I try to start it normally.
I then tried to access it in recovery mode: the leds start flashing from left to right until all leds are lit up, they stay lit up a short while and then turns off. Then power turns on and after a short while powerled and the two closed to it and the recover led is lit up. It stays that way but I can’t connect to the server.
I figured maybe I pressed the recover led to long so it booted up with static ip so I tried to connect it to 3 different pc:s om which I changed network settings to:
ställer pc på 192.168.81.5
submask 255.255.255.0
def gateway: 192.168.81.1
HC2 begins to boot up normally but when all leds where lit up the led furtherst to the left is lit for a while, then all leds turned off and nothing else happened. This still occurs when I try to start it normally.
Still connected to the pc I then tried to connect in recovery mode but that does not work either. This time when I boot hc2 up its starts normally by flashing leds from left to right and ends with all lit up a short while. Thereafter power and recovery leds are lit up.
I still can’t connect to the server by entering 192.168.81.1 in the webbrowser and 192.168.81.1 does not respond to ping.
I would really be grateful for any hints on how to fix this
/emoticons/default_icon_smile.gif" alt=":-)" />4 answers to this question
