Mitsubishi AC over wifi (MELCloud)
Hi all,
I'm almost ready to buy the MSZ-EF25VEW AC unit with the WiFI module. Now, since it will have an IP in the internal network, is there any chance I can use the HCL to control it?
Cheers,
ALF
+1 would like to see melcloud addon in fibaro home center 2!
Hello miroslav.petrov. How could I help you with LUA? I'ld be very interested too with Melcould integration however please note that my Fibaro H2 is in box during homework. I'm very interested in your reverse engeneering findings. please let share with me and will try to translate it with LUA.
Thanks to get in touch.
This is integration with homey -
 it works OK. I provided HeatPump access for the developer and helped him test for homey. But homey was not stable so...trying my luck with HC3 :)
If some developer would be interested I could help with general stuff.
This file is the main driver for  HeatPump -
This file is the main driver for  AirCondition -
I have a Geodan with melCloud and with HC2 i can only get the 'Token' from the first request but cannot use it as a header with next requests.
Header is 'X-MitsContextKey' so im guessing its not supported with HC2..
Post is already old, but still i can not find a good interface with
or wifi module for Mitsubishi airco with fibaro intergration
or wifi module for Daikin airco with fibaro intergartion.
Does anybody find a plugin.
And while we are busy maybe also for a heatpump?
Try here:
Works for me and the developer is willing to help if you have issues.
